Go Back   SR20 Forum > Vendor Customer Support > CalumSult > Realtime ECU support
Old 07-22-2007, 04:06 PM   #1 (permalink)
AaroNX
Help needed...
Ok what I'm trying to do is simply change the rev limiter on my realtime. The bin that is on it is supposed to be for a stock program. I'm using tunerproRT and trying to figure it all out. When I go to open the bin it comes up with two different ones. One is apyp and the other is arap. I'm not sure which one I should go to, but they are both different. Also how do I know what to change the numbers to in the rev limiter RPM? Right now in the apyp bin it says the rev limiter is 173387.50 RPM.
If anyone can help guide my computer illiterate ass through this I'd be greatly appreciative.
http://phatboyaudioonline.com/
1993 NX2000-5SPD SWAP, 2120lbs. JDM Motor, Calumsult Realtime ECU, Brian Crower STG 3 cams, CP XTP 9.2:1 pistons, NX DP-100 shot, Prothane Mounts, ACT Xtreme/street disc, PR CAI with JWT POP, SSAC with 2.5" downpipe, Dynomax 3" muffler, Outlaw Intake Spacers, OEM wires with ngk plugs, UR Pulleys, Walbro 190, ST springs with KYB's, Xstatic Batcap, Axis maglites
Old 07-22-2007, 09:24 PM   #2 (permalink)
AaroNX
Ok I got all that sorted out with help from Ben, thanks alot man.
NOW I'm trying to put the tuned NA bin on the ecu. I have it on the laptop and it's on tunerproRT but how do I put it on the ecu itself? When I hit the thing that says Verify Emulator Ram Contents against Current Bin, the window pops up telling me that tunerpro has encountered a problem and needs to close.
Old 07-22-2007, 09:49 PM   #3 (permalink)
AaroNX
While I'm at it, if anybody has a tuned bin that's closer to my mods please let me know.
Old 07-23-2007, 12:05 AM   #4 (permalink)
AaroNX
While I'm at this anyone know where I can get nissandatascan now? The link I found is no longer valid?
Old 07-23-2007, 12:17 AM   #5 (permalink)
budsang1
Beware....THE BEAR!!
budsang1's Avatar
Trader Rating: 36 (100%)
this is where i got mine...you pay 35 for the program...once he sees you don't want the software shipped to you, you'll get refunded 5 back to your paypal
http://www.blazt.biz/
budsang1 is offline   Reply With Quote
Old 07-23-2007, 12:26 AM   #6 (permalink)
AaroNX
Thanks!!!
Old 07-23-2007, 12:47 AM   #7 (permalink)
AaroNX
Lol I put it on my desktop no problem, but when I went to put it on my laptop it keeps telling me to insert disc 52??? I manage to mess up everything when it comes to computers.
Old 07-23-2007, 07:22 AM   #8 (permalink)
budsang1
budsang1's Avatar
really...disc 52? I just installed it to my laptop...with no problems
Old 07-23-2007, 09:59 AM   #9 (permalink)
AaroNX
I'm sure it has something to do with my laptop being a pos from the 70's lol.
Old 07-23-2007, 10:44 AM   #10 (permalink)
Calum
soylent green is people
Calum's Avatar
Approved vendor
Trader Rating: 22 (100%)
Use EmUtil for uploading a complete new bin to the ecu. See quickstart guide for instructions. Got the rev limiter figured out?
calum@calumsult.com
Old 07-23-2007, 10:45 AM   #11 (permalink)
Calum
Calum's Avatar
Approved vendor
Old 07-23-2007, 01:06 PM   #12 (permalink)
Octave236
like a stray puppy
I think i had a commodore or something like that when i was like 4 or something. all i could do was make smiley faces on it
1993 NX2000: Weekend fun car
1990 Accord: New to me Daily Driver
Octave236 is offline   Reply With Quote
Old 07-23-2007, 01:09 PM   #13 (permalink)
Octave236
like a stray puppy
we got the rev limiter figured out I believe. He was able to pull the bin off the emulator and tweak it. I was wondering when you load a completely new bin does it just overwrite the old one, so no need to clear it off or anything.
Old 07-23-2007, 01:18 PM   #14 (permalink)
Calum
Calum's Avatar
Approved vendor
Cool. Yes.
Old 07-23-2007, 01:20 PM   #15 (permalink)
Octave236
like a stray puppy
cool... straight to the point i see
Old 07-23-2007, 02:32 PM   #16 (permalink)
AaroNX
So is Emutil part of tunerpro or something different? I guess I should check the quick start thing again huh.
Thanks for the help guys. And if your wondering the laptop is a dell latitude cpi. I think it might be the first one too lol. Like I told Ben though I can't complain it was free.
Old 07-23-2007, 02:38 PM   #17 (permalink)
AaroNX
Ok I read the quickstart thing again. I downloaded the emutil thing before but I don't think I put it on my laptop, so I'll download it here and put it on later. Right now I'm fixing my massive coolant leak.
Old 07-24-2007, 12:43 PM   #18 (permalink)
AaroNX
Update, I was able to put the tuned bin on the ecu, but it won't let me change the rev limiter on it for some reason. It said it couldn't write it and then said it couldn't save the bin when it closed. It seemed to work fine when I did it to the stock bin that was on the ecu.
Old 07-24-2007, 12:55 PM   #19 (permalink)
Octave236
like a stray puppy
Did tuner pro tell you hardware was connected and that you were emulating ??? Every now and then I had to play with it to get it to locate the hardware.
Old 07-24-2007, 01:14 PM   #20 (permalink)
AaroNX
Yeah it does those no problem. When I change the rev limiter and tell it to update, it says something about not being able to write file, yet at the bottom says update completed. However when I turn tunerpro off it says the file has been changed and asks if I want to save it, I tell it yes and it says it can't do it. After that when I open tunerpro again it tells me the rev limiter is back at 7800.
