Go Back   SR20 Forum > Vendor Customer Support > CalumSult > Realtime ECU support
Old 09-20-2007, 10:28 PM   #1 (permalink)
No cruise and CEL issues..
Hey Calum,
I have had my RT ECU for a long time now, since the beginning of the year, and ever since then I have had issues with the cel turning on and off very frequently. I have messed with a bunch of different things in the tune and what not with no avail. Also, the cruise light turns on and recognizes that it is set, but nobody is home, I wonder if the ECU you got me was out of a car that didn't have cruise.
el tigre is offline   Reply With Quote
Old 09-20-2007, 11:23 PM   #2 (permalink)
soylent green is people
Calum's Avatar
Approved vendor
Trader Rating: 22 (100%)
The ecu doesn't connect to the cruise system. This is a 240, right? Let me check and make sure, but I'm 99% sure thats a separate system.
On the CEL light, is the knob on the back of the ecu turned all the way back to the reset position? I take it its not actually throwing a code? When you check with NDS or ConZult Freeware does it return a 55?
calum@calumsult.com
Old 09-20-2007, 11:37 PM   #3 (permalink)
It actually says there is no code, I don't get a code 55.
Yeah, it is 240. The cruise worked before, I guess I can recheck everything else. I will have to check the nob on the back the ecu when I go home next weekend.
I assume that is probably what it is because of the lack of a code 55. I didn't think of that.....
Old 09-21-2007, 08:49 AM   #4 (permalink)
Calum's Avatar
Approved vendor
Its getting a 55, its just translating that to 'no code'.
Old 09-21-2007, 12:11 PM   #5 (permalink)
I have used conzult for all of my code reading, etc. I recall getting an actually code 55 on there before,..... maybe. Now I don't think I get that. I'm unsure though....
Old 09-21-2007, 12:44 PM   #6 (permalink)
Calum's Avatar
Approved vendor
In ConZult, does it detect the ecu, and do all the gauges work correctly?
Old 09-21-2007, 03:21 PM   #7 (permalink)
Sometimes. I have the free one. It is a bit of a pain, it has taken me like 15 minutes to get it to recognize the ecu. I plan on getting NDS sometime soon when I start working on the car again.
Old 09-21-2007, 05:32 PM   #8 (permalink)
Calum's Avatar
Approved vendor
Really? It should recognize it right away. What does it do when it doesn't recognize it?
Old 09-21-2007, 05:49 PM   #9 (permalink)
It just says that there is no connection with the com port that I select, which is the correct one, I can't recall which one it is at the moment though... Otherwise I like the ecu, lol...
