Hey calum, havent repsonded to emails so i figured id try this. Need 650cc's at whatever fuel pressure you reccomend, Z32 Maf, T3,T4 50trim .48ar.
Also wanted to know what codes etc i need to run nissan datascan for maptracing/ datalogging.
Also when datalogging with nissan datascan would i be able to see if my cam timing is off? IE. If my cams were installed wrong, would i be able to see the loss in total timing through the datalog, or is it only refrenced from base timing?
Any word on nistune? Is it fully funtional for Calum Realtime S14's?
Last question about tuning. Do you just do a pull, say for full boost, then look at your TP on that boost and adjust accordingly until full throttle is max tp? Also when adjusting fuel/ timing values are you just holding the vaccum at for example 10 throughout the rpm range, then adjusting the cells that highlight at that load?
Email is
tanmans14@hotmail.com if you need to send the tune that way.
