Map trace follows only one path - SR20 Forum
Old 06-17-2008, 04:22 PM   #1 (permalink)
Feedback Score: 14 reviews
I just got my b13RT 2 weeks ago. I tried tuning using Nissan Datascan and TunerPro RT. The base tune from Calum is OK, but when I trace the fuel using Datascan it just follows one diagonal path from corner to corner. It doesn't matter what the load is, it alway follows a linear diagonal path. I'll try to get a screen shot up later, but I know its not normal.
The trace stays on that path when I let off the accelerator(instead of shifting over to the left most column for TP), the computer still dumps fuel as if the engine is still under load. When I shift, it always backfires and actually blew the gasket on the turbo and by the cat.
I tried changing the MAF for another one and same problem.
Any theories why this is happening?
JRock is offline   Reply With Quote
Old 06-17-2008, 05:21 PM   #2 (permalink)
About 5 minutes worth of trace during WOT, light throttle and downshifting.
The screenshot is me engine braking in 2nd to pull in my driveway:
Old 06-18-2008, 07:17 AM   #3 (permalink)
Feedback Score: 17 reviews
Is this a stock B13 (with bolt-ons) and Calum's standard tune? The trace does not look right. When you open the throttle, the trace should move horizontally across to the 104 column, then straight down as RPMs build. I'm wondering if the specs for Map Trace are set correctly.
Old 06-18-2008, 08:28 AM   #4 (permalink)
Yes, that's what I'm wondering. I've looked on youtube and seen how the ECU handles load on the map. Mine behaves in a linear fashion wether its at WOT or no load.
I'm wondering if it is a problem with datascan not reading the ECU properly(not likely), or an ECU issue, or a sensor problem
Oh, its a b13 with Avenir swap, SE-R MAF.
Old 08-15-2008, 10:39 AM   #5 (permalink)
S14 Newbie
I have the same thing with my S13. I, too, think it's a datascan problem not using the correct address to pull the TP from my 62 ECU.
Calum, Can you provide us with the correct address for reading TP.
JROCK, what ECU are you using?
TSuaVe is offline   Reply With Quote
Old 08-15-2008, 11:05 AM   #6 (permalink)
ClamSlut
Calum's Avatar
Feedback Score: 26 reviews
What TP address are you using? Are you using the address listed in this thread?
http://www.sr20forum.com/calumsult/1...cing-cool.html
Old 08-15-2008, 01:00 PM   #7 (permalink)
I sold the ECU cause I no longer have the car. It was a b13RT ecu.
