AEM UEGO Wideband Install - SR20 Forum
Old 03-04-2009, 01:29 PM   #1 (permalink)
I <3 VVL
Feedback Score: 11 reviews
I have an AEM UEGO Wideband sensor and I was wondering if it can be wired right into a Calum RT (which I also have). If not, how am I supposed to hook it up?
This is all the info I found in the Install manual and an ECU pinout for 95-97 ECU.
The 5 (7 on the 30-2300) wires should be hooked up as follows:
Orange Sensor #1 0-5 Volt Output
White Sensor #1 0-1 Volt Output
Blue Sensor #2 0-5 Volt Output (on 30-2300 only)
Green Sensor #2 0-1 Volt Output (on 30-2300 only)
Brown Signal Ground (use only on systems with a differential input)
Red Switched +10 to +18 Volts (10 Amp Fuse Required)
Black Battery Ground
98 Sentra SE VVL
VE-T Thread
Tonyklem is offline   Reply With Quote
Old 03-05-2009, 11:16 PM   #2 (permalink)
Feedback Score: 31 reviews
Bump... would also like to know!
Old 03-07-2009, 01:20 AM   #3 (permalink)
ClamSlut
Calum's Avatar
Feedback Score: 26 reviews
I can't find a pdf for the 30-3300. Is this the gauge controller or the box type?
http://www.aempower.com/ViewCategory.aspx?CategoryID=67
Old 03-07-2009, 10:25 AM   #4 (permalink)
Mine is a gauge.. i think his is too.
Old 03-07-2009, 12:05 PM   #5 (permalink)
Feedback Score: 20 reviews
Very interested myself too!!!
Here is the manual for the latest AEM UEGO that you can purchase: http://www.schnitzracing.com/manuals/AEMWBK.pdf
"Vadim" @ Dash
Old 03-09-2009, 12:28 AM   #6 (permalink)
I <3 VVL
no, mine is a non gauge type (controller box). Here is the PDF.
http://forum.aempower.com/forum/inde....0;attach=4376
Oh, sorry I just realized the pdf has a typo and says 30-3300. But it is the 30-2300 (Edited it in the above posts)
Old 03-11-2009, 04:49 PM   #7 (permalink)
Feedback Score: 9 reviews
So, any thoughts yet as of how to hok it up?
M0J0 is offline   Reply With Quote
