Emulation Issues - SR20 Forum
Old 05-15-2010, 08:00 PM   #1 (permalink)
DPS
Emulation Issues
I'm currently tuning a '91 KA24DE with the B13/S13 Calum RT ECU. I'm using TunerPro RT with DataScan and have the Map Tracing feature working.
The problem that I'm having is that when I go to the corresponding Primary Fuel table in TunerPro I am seeing no effect from my changes. I've shifted the entire table by 10% and the WBO2 doesn't change.
TunerProRT says that it's connected to the Romulator and "Emulating" is in green after I initiate it. I thought maybe my problem stemmed from not pressing "Update" after I changed the table. I tried it and it said "Upload Failed." Then I figured it failed because the car was running.
Datascan seems to work well. I can change fueling with "Active Test."
I also tried EmUtility. It connects to the Romulator but I get "FAILURE: Cannot read 0 bytes" when reading the bin to a file.
I'd appreciate any help.
Thanks,
Brad
DPS is offline   Reply With Quote
