Go Back   SR20 Forum > Motorsports > Road Racing
Old 08-21-2007, 12:01 PM   #1 (permalink)
Shift_Munky
A.K.A. 2Fass240us
Inline Oil Filter
I have recently been giving some consideration to using an inline oil filter, and found some Peterson ones at used race parts stores. After looking at them online and speaking with a technical rep (Kevin), it seems like they may be a decent idea. I am leaning toward the 09-0451 with -10 AN Fittings and an internal bypass.
Pros
1) Cheaper in the long run since I don't have to keep replacing spin-on filters
2) Less pressure drop across the filter (good for stock oil pump)
3) Larger filtration area (19.63 inČ for K&N HP-1003 and 32.99 inČ for Peterson 09-0461); this could be partially solved by using a larger spin-on filter with a remote mount
4) Fewer fittings, thus fewer potential leak points than a standard remote mount with female 1/2" NPT fittings and -AN adapters threaded in
Cons
A) More of a pain to clean the element than replace a spin-on
B) May need to clean after every track weekend to ensure clogging doesn't occur
C) Filtration isn't as good (K&N lists "10-20 micron" for the filter and the Peterson uses a 60-micron element)
I noticed bigtoe used these in his dry-sumped motor, and wondered if it is at all detrimental to use on a motor with a stock, new oil pump. Motor is a rebuilt RWD SR20DET with stock turbo. Car is used for HPDE's and autocrosses only, and is only street driven to warm up the oil enough for an oil change.
TIA,
Andy
240SR track donkey
Old 08-23-2007, 01:20 AM   #2 (permalink)
choaderboy2
Pros
Cons
TIA,
Andy
I used these when I was at TRD on our GT cars and noticed they caught metallic debris when something bad happend.
Not sure if they pick up fine stuff.
2006, The year of the Dog Car
choaderboy2 is offline   Reply With Quote
Old 08-24-2007, 11:34 AM   #3 (permalink)
Shift_Munky
A.K.A. 2Fass240us
So you're saying they may not be a good idea on a street-based engine?
I was talking to another guy who isn't big on them for my application and I mentioned that they're used in NASCAR, to which he responded "yeah, but they rebuild motors every race."
Jury's still out, but I would need to make a decision in the next week or two. No other input?
Old 08-24-2007, 12:33 PM   #4 (permalink)
NX$paniard
easy 400WHP
Trader Rating: 26 (100%)
What about a combination of an inline filter first, followed by a conventional spin-on? If it didnt create too much pressure loss, I would think that would cover alot of filtration needs...
~jRod
Old 08-24-2007, 12:42 PM   #5 (permalink)
Shift_Munky
A.K.A. 2Fass240us
I thought about that, but it would negate the majority of reasons I'm considering the inline filter, primarily fewer leak points and less pressure loss.
Old 08-24-2007, 12:44 PM   #6 (permalink)
NX$paniard
easy 400WHP
using properly built/good aluminum AN fittings you shouldnt see many leaks.
But I hear ya...
Old 08-24-2007, 12:58 PM   #7 (permalink)
choaderboy2
I don't reember what the fitration specs were but I don't think they filter all that well compared to a regular spin on filter. I would just use a chepo remote with a fram PH-1, I have been using that for awhile and it seems to do fine and is cheap.
Old 08-24-2007, 02:08 PM   #8 (permalink)
McCoy I am a moderator
SR powered S13 coupe
McCoy's Avatar
Trader Rating: 74 (100%)
Andy, the canton oil filter I run on the outback filters to 8 micron... this is better than the typical oil filter (not sure of the filteration # though).
The remote canton filters are not that expensive, if you haven't looked at them yet.
http://www.racerpartswholesale.com/canton1.htm
Old 08-24-2007, 06:08 PM   #9 (permalink)
Shift_Munky
A.K.A. 2Fass240us
I've seen them, but was under the impression the elements weren't cleanable. And at $13/pop, oil changes will become even more expensive.
Also, any idea about pressure drop across these with the 8 micron elements?
Old 08-24-2007, 06:29 PM   #10 (permalink)
McCoy's Avatar
Correct, the elements are not cleanable... canton recommends that they are replaced every 15K miles IIRC. I replace my filter once every year and replace all the rubber parts every 2 years.
As for pressure drop, not sure. The part I like about this filter is that there is no bypass like the OEM style oil filter, so the oil is filtered 100% even under WOT.
Brian (coworker who tracks his STI) has been using his with both his WRX and his STI over a period of 5 years now. He puts on alot more track time per year than I have... actually, half his milage of the car was put on the track.
Old 08-26-2007, 09:25 AM   #11 (permalink)
Shift_Munky
A.K.A. 2Fass240us
I have been thinking about this, and it's not on the table along with the Peterson filters. The standard spin-on just won't cut it for me...I just think they're too messy even when remote-mounted. I like the CM remote canister filters because they remind me of my M3's oil filter housing, which is a NICE feature. The ability to pop the top, and replace the element with hadly any mess in hardly any time is very appealing.
The CM seems to filter to an even lower level than the Peterson and element changing will be easier, particularly since I won't have to undo any -AN fittings to do so.
Only issues:
1) Figuring out where to mount
2) Bottom inlet will pose some "trying to get away from using 90's" concern
3) -12 inlet and outlet are larger than I want
Possible solutions:
1) & 2) mounting at an angle might solve this problem
3) -12 male to -10 male adapters are abundant
Old 08-26-2007, 12:05 PM   #12 (permalink)
McCoy's Avatar
Andy, I noticed that a few of the places selling the CM filters also sold 12AN to 10AN adapters... maybe with a call they could just replace the 12AN fitting with the reducers at no cost .
Old 08-26-2007, 03:11 PM   #13 (permalink)
Shift_Munky
A.K.A. 2Fass240us
Where did you get yours? The only other place I found that sells them (w/a quick Google search) was Livermore Performance. The price there on the filter I'd want (6" tall) is $13 less than on the CM/Canton site.
Old 08-26-2007, 03:26 PM   #14 (permalink)
McCoy's Avatar
Pegasus, but there probably not the cheapest...
http://www.pegasusautoracing.com/gro...ID=OILFILTCANT
Old 08-30-2007, 03:53 PM   #15 (permalink)
Shift_Munky
A.K.A. 2Fass240us
OK Monty, you convinced me. I ordered from Pegasus because they offered the -12 o-ring to -10 male adapters as well. I purchased those, the filter, and an additional mounting clamp.
I'll take some pictures when the stuff comes in and put them in my thread. Speaking of which, my thread and car are jealous of your progress.
Old 08-30-2007, 04:03 PM   #16 (permalink)
McCoy's Avatar
Sweet! I will be following you soon enough on this one, so make sure to take plenty of pictures and notes on this one
Did you get the 4" or 6" tall filter?
Old 08-30-2007, 09:19 PM   #17 (permalink)
bigtoe
Always Different !
Look up the Micron Size options on the various elements, Mike is correct they are not as efficient as a good Paper Element Filter. For a street car you should stay with the better quality paper spin on filters.
I used these on the race car simply because they are in line and save on space.
Unless you have something like an Ultra Sonic Cleaning Bath thenn forget about trying to think you can clean it effectively enough...........especially after any major incident in the motor.
BIGtoe
Beware of, "Repetitious Mupitism"
bigtoe is offline   Reply With Quote
Old 08-30-2007, 10:55 PM   #18 (permalink)
Shift_Munky
A.K.A. 2Fass240us
You know me, man. I can't NOT take lots of pictures of something like this.
I bought the 6" (durrr).
I might give the inline ones a go when I add a sump sometime down the road. By that point though, it'll probably be time to drop in a LSx. The CM filter comes with an 8-micron element, which should offer superior filtration to the "10-20" of the K&N spin-ons I like to use. Not only that, but they'll be less messy to change.
I'll post some chit up when I get a chance.
-Andy
