building a road race car - SR20 Forum
Go Back   SR20 Forum > Motorsports > Road Racing
Old 12-02-2007, 07:40 PM   #1 (permalink)
sqd
b13 gtir
so far it's been over a year since i started building my car. with the constant help of kojima it's getting closer and closer to being finished.
i picked the car up in june of 06. i had just transferred high schools in the middle of the year and had an F in math because the curriculums were completely different and since math builds off itself, i did not have the proper background. anyways i told my dad i would get a 3.0 no problem because i was doing well in all my other classes. he said there was no way so we made a bet. if i could pull of a 3.0 with an F in a class he would get me a racecar. end of the year and 3.2 =] (pretty damn good off the bat for a transfer student). he was really really pissed so i made up the class in summer school and he told me i better get an A and if so the deal was still on. A+ baby.
so heres the start to it:
stripping the interior:
buddy james removing firewall firemat:
buddy mihai removing seam sealer:
all stripped:
car went to technosquare in october.
main hoop:
seat rails:
gusseting:
up to front strut towers:
nascar bar:
almost done:
then the car came home and i meticulously painted and primered it.
zinc chromate aircraft grade primer:
rustoleum industrial grade machine grey:
then the engine bay:
and brakes:
interior all painted:
now reworking all the brake lines. 75% finished. all done by my hands.
altima master cylinder:
fronts:
tilton proportioning valve to rear:
all my goodies:
as it sits now by project phoenix:
what do you guys think?
sqd is offline   Reply With Quote
Old 12-02-2007, 08:14 PM   #2 (permalink)
I live for the weekend
Feedback Score: 6 reviews
I think I'm jealous stephen. haha
what's going to be the suspension setup?
SR20DEEP
1993 Nissan Sentra SE-R
275whp & 278 ft/lbs torque @ 12 lbs boost
prodrifter is offline   Reply With Quote
Old 12-02-2007, 08:30 PM   #3 (permalink)
_______
spnx's Avatar
Feedback Score: 4 reviews
Car looks great. The wheels should hold up well - I've been running them since 1998. I'd suggest taking your nice new RA1s and Volks off for when you're working on the car though! You don't want to get them banged up or get paint on them.
I'm curious about the suspension too. From the pics, it looks like a nice street coil-over set. Wondering if it would hold up to race conditions.
Do you have camber plates on all four corners? You picked up the right plates. If I were to do it again, I'd get the GC style, rather than the Cuscos, which mount on the underside of the strut tower and eat up some suspension travel.
James
spnx is offline   Reply With Quote
Old 12-02-2007, 08:30 PM   #4 (permalink)
sqd
b13 gtir
haha dont be its super tedious to build to my liking.
im running advance design struts with adjustable rebound and damping with a digressive damping curve, ground control coilover kit with eibach springs, front and rear ground control camber plates, and energy busings all around.
Old 12-02-2007, 08:34 PM   #5 (permalink)
sqd
b13 gtir
the wheels are my neighbors. had to borrow them because my stock wheels didnt clear the brakes. my stupid mistake. gave them back when i picked up my 5zigen fno1r's.
yes i am running the ground controls on all four corners. the suspension is race proven and the ground controls seem pretty buff.
Old 12-02-2007, 09:20 PM   #6 (permalink)
Feedback Score: 22 reviews
Wow, totally jealous for sure! That cage is really nice! Car is coming along really well. What are you going to fill the sunroof with?
As for the MC, is that a non-ABS unit with two ports plugged? Don't they usually have the big hex nut thingies on 'em?
_SHig
SHigSpeed is offline   Reply With Quote
Old 12-03-2007, 12:45 AM   #7 (permalink)
Oh your the guy with Kojima's old car. Kid your B13 loaded. Have fun out there man , and be safe.
You cali guys always have the $$$$$ cars, lol.
Old 12-03-2007, 02:55 AM   #8 (permalink)
sqd
b13 gtir
_SHig
i bought a metal shrinker to bend the aluminum around the radius of the sunroof. i was planning to pop rivet the frame in and nutsert/allen bolt a sheet of aluminum onto that. there is a bar going right under it so the cover doesnt have to be super strong. MIGHT do carbon fiber just for looks. aluminum is pretty light as it is.
the master cylinder IS ABS. picked that one because it is bigger. i eliminated abs from the car including from the wiring harness.
here is what i'm doing:
front: master cylinder port 1 -> brake T fitting -> left & right
rear: master cylinder port 2 -> proportioning valve -> brake T fitting -> left & right
Old 12-03-2007, 12:07 PM   #9 (permalink)
Now finish the damn thing.
2006, The year of the Dog Car
choaderboy2 is offline   Reply With Quote
Old 12-03-2007, 01:45 PM   #10 (permalink)
pwnd
Only a few things i see from my untrained eye.
Why nascar bar, then the bar also close to the driver? I would like a little more driver room personally. And if you are going nascar bars, you can make it strong enough and hang it out there a bit.
Then why the adjustable rails? Do you see using it like at an enduro with multi drivers? Why not a more secure mounting that is fixed?
What class you going racing in? Cause I know like ITA you cant tie into the front strut towers like that.
Like spnx said, get GC camber plates. you can modify them to fit on the rear as well with some work. But you will be looking at a lot more custom work on rear suspension as well.
Personally Id go lot stiffer springs and koni double adjustable with race valving. but we all know how bad the b13 suspension sucks...so its not easy or cheap to make it go around a corner not looking like a snow plow
-Kevin
We are a community
Old 12-03-2007, 04:05 PM   #11 (permalink)
I think he's going racing with NASA. Looks like most of the sentra guys out in Cali are NASA guys.
Old 12-03-2007, 04:38 PM   #12 (permalink)
[sr20]sean
Feedback Score: 20 reviews
looking good
dcr1d3r13 is offline   Reply With Quote
Old 12-03-2007, 05:20 PM   #13 (permalink)
sqd
b13 gtir
never had any issues with clearance. it really isnt that close
multiple drivers and driver comfort. im 18 years old and still growing.
NASA PTE/PTD not sure.
Like spnx said, get GC camber plates. you can modify them to fit on the rear as well with some work. But you will be looking at a lot more custom work on rear suspension as well. Personally Id go lot stiffer springs and koni double adjustable with race valving. but we all know how bad the b13 suspension sucks...so its not easy or cheap to make it go around a corner not looking like a snow plow
as i stated above:
"im running advance design struts with adjustable rebound and damping with a digressive damping curve, ground control coilover kit with eibach springs, front and rear ground control camber plates, and energy busings all around."
then again:
"yes i am running the ground controls on all four corners. the suspension is race proven and the ground controls seem pretty buff."
and i will add that i am running progress sways in front and rear and a progress subframe support in the front.
Old 12-03-2007, 06:07 PM   #14 (permalink)
pwnd
nice way to get pissy....
just didnt sink in that you said it for the rears...and in the pics dont see the rears at all...just see the front gc plates.
Old 12-03-2007, 06:49 PM   #15 (permalink)
geez wish i could make deals like *** with my dad!!! oms. cant wait to see thee nd product
iF iTS BeTTeR THaN MiNe..... iT SuX!!!
God Created turbo lag... To Give V8's a chance
www(.)sr20(-)forum(.)com remove ()
L4t3cy is offline   Reply With Quote
Old 12-03-2007, 06:50 PM   #16 (permalink)
sqd
b13 gtir
sorry about that didnt mean to come off that way!
Old 12-03-2007, 08:39 PM   #17 (permalink)
A.K.A. 2Fass240us
The only growing I did after 18 was outward.
Lookin good. I'm more jealous that you're getting into it this early than of the car itself. Best of luck.
-Andy
240SR track donkey
Old 12-03-2007, 11:14 PM   #18 (permalink)
I can't see how you could say he was getting pissy.
Old 12-04-2007, 01:02 AM   #19 (permalink)
NASA #92 PTD
Bring it out - we need the cars... You going to be back next year Mike?
Derrick Malcolm
Enterprise Automation/Malcolm-Racing
#92 - Nissan Sentra SE-R
NASA Southern California - PTD
www.malcolm-racing.com
derrick is offline   Reply With Quote
Old 12-04-2007, 01:58 AM   #20 (permalink)
Occasionaly but not a full season, with my mom to take care of now, I don't like being away from home more than I have too.
