?'s - SR20 Forum
Go Back   SR20 Forum > Motorsports > Road Racing
Old 05-19-2009, 02:50 PM   #1 (permalink)
Gaining
Feedback Score: 25 reviews
?'s
I have a question for those of you guys who have cages in your SE-R (b13).
How far from the floor are your harness bars mounted/welded to your cages? I ask because I have a autopower roll-bar that doesn't have a harness bar, and I want to get one welded on.
I have one more question for you guys regarding bushings.
Do the Whiteline caster bushings provide any additional caster to those with Ground Control camber plates, and is their hardness/density any better than that of the Energy Suspension bushings?
Any help would be greatly appreciated.
Thanks, Mike.
blackcloud is offline   Reply With Quote
Old 05-19-2009, 03:57 PM   #2 (permalink)
The anti-Probe.
You should just put your seat in the car and measure up about 6" from the harness holes. That should put the bar in the right place. The important thing is for your harnesses to pull you into the seat and not push down on your shoulders. The installation instructions will have an angle for the harness to from your shoulders to the bar.
The caster bushing come in 2-4 different hardness levels and they are all harder than the ES bushing material. I think that the ES stuff is Poly and the caster bushing is delrin.
They will provide some additional caster over what you will get with the caster/camber plates but I don't know how much because I have never tried to measure it. I max my caster out with the plates and leave it.
#67 Sentra SE-R
2007 NASA-MA Rookie of the year
2008 NASA-MA PTE Champ
2009 NASA-MA PTE Roadkill
2010 NASA-MA PTE "If it can break, crash, or burn.... it will."
awdracer is offline   Reply With Quote
Old 05-19-2009, 04:48 PM   #3 (permalink)
SE-R Cup #2
Also, if you max out your camber with the CC plates, you generally have little to no adjustment for caster.
Wade is offline   Reply With Quote
Old 05-19-2009, 05:50 PM   #4 (permalink)
wants to go play
Blair's Avatar
Feedback Score: 5 reviews
+1 for the what seat are you using?
Yes, I believe I got a degree or close to it from them.
91 NX2k hard top (track whore) Celebrating 14 years of ownership!
93 SE-R (street/track toy) Overkill is just about right
93 SE-R (daily driver) 221k and counting!
Old 05-20-2009, 02:37 PM   #5 (permalink)
Gaining
Thanks for the input guys. It's greatly appreciated.
Old 05-20-2009, 02:40 PM   #6 (permalink)
Gaining
I'm using a Corbeau FX1 Pro.
Old 05-20-2009, 05:31 PM   #7 (permalink)
The anti-Probe.
What he meant was that he agreed with my suggestion to mount your seat first and then measure the place to put your harness bar based on the recommended angle for harness installation.
