Go Back   SR20 Forum > Motorsports > Road Racing
Old 01-31-2004, 02:42 PM   #1 (permalink)
grover
Spoiler/Splitter
I *finally* have the writeup and pics posted:
http://www.nissport.com/spoiler/default.asp
Grover
grover is offline   Reply With Quote
Old 02-01-2004, 09:40 AM   #2 (permalink)
98sr20ve
Thanks for posting that. Good article. Using the poster boarde is a great idea. What thickness where the materials and what size was that first piece of Polyethelyne you purchased. I assume you used just one peice for the entire project but want to confirm the thickness of everything.
Steve
06 G35 6MT
Old 02-02-2004, 05:45 PM   #3 (permalink)
grover
I went back and revised the article.
It was a single 8x4' sheet. There was plenty leftover for more spoilers. But, at 20x60", only one splitter can be made (if you use the same sheet for a spoiler). It was .250" thick.
Grover
Old 02-10-2004, 09:40 PM   #4 (permalink)
hybrid D E T
since 2001
Have you ever been able to get a riv nut to hold in place while installing it in a plastic bumper? The reason I ask is, I've been trying to use riv nuts to mount a lower air dam, only to have the threaded insert deform the hold and then pull through. I ended up using 10-32 button heads with a nut to hold it on like you did on your spoiler.
Chuck
Shamless Myspace plug
1988 B12 Nissan Sentra SR20DET
1991 240SX SR20DET, Project 240SR
1991 NX2000 SE-R Cup #75
1991 Nissan Sentra SE-R, 24 Hours of Lemons
hybrid D E T is offline   Reply With Quote
