Go Back   SR20 Forum > Motorsports > Road Racing
Old 07-19-2004, 06:20 PM   #1 (permalink)
Rockwood
70/30 Racing
Rockwood's Avatar
roll bar gusseting?
is it legal to run roll bar gusseting from the forward bars to the A pillar in SR? or is this considered an extra or illegal attachment point?
Steve Rockwood
92 G20 - PTD #73
Old 07-20-2004, 12:37 PM   #2 (permalink)
Jim #98NX
Traitor in your midst
Re: roll bar gusseting?
Yes, this is illegal. The A pillar bars can only attach to the A pillar in SRX.
-Jim
SE-R Cup Hooligan
Jim #98NX is offline   Reply With Quote
Old 07-20-2004, 12:37 PM   #3 (permalink)
Rockwood
70/30 Racing
Rockwood's Avatar
okay. thanks!
Old 07-21-2004, 11:20 AM   #4 (permalink)
tpeele
Why make this illegal? If somebody wants to build a safer cage why penalize them? I would rather do this in my car since it will make the installation much cleaner. One less bar that I will need to put in.
Thanks,
Tim
95 M3
05 Pathfinder
http://pg.photos.yahoo.com/ph/tpeele...c0.jpg&.src=ph
tpeele is offline   Reply With Quote
Old 07-21-2004, 11:39 AM   #5 (permalink)
Jim #98NX
Cage is limited to six attachment points and an optional 2 firewall braces.
One less bar? You guys are talking about this, right:
Connecting the cage to the A pillar the length of the windshield (or at all) is not allowed. Sorry.
Old 07-21-2004, 12:41 PM   #6 (permalink)
Geo I am a moderator
NISsport
Geo's Avatar
Thanks,
Tim
It seems to me this makes far more difference in stiffening the chassis than it does making a safer cage. In fact, the energy absorbed in crumpling the sheet metal would be that much less energy the cage itself would have to absorb.
George Roffe
91 SE-R (well modded)
http://www.nissport.com
Geo is offline   Reply With Quote
Old 07-21-2004, 12:53 PM   #7 (permalink)
choaderboy2
Thanks,
Tim
Doesnt help safety much, stiffens chassis a lot adds to expense a lot. SR is supposed to be an inexpensive class.
Mike
choaderboy2 is offline   Reply With Quote
Old 07-21-2004, 01:09 PM   #8 (permalink)
Rockwood
70/30 Racing
Rockwood's Avatar
Thanks,
Tim
guesseting is taking perforated steel and welding it from the forward bars to the a pillar. pays dividends in chassis stiffness, but not so much to the cage. you do not get to lose a bar, as the bar is much stronger than just a 1/16" thick peice of steel with holes in it.
i didnt see anything specific on this, so i assumed it went under the attachment points clause. i just wanted to make sure, as i have seen it on some cages (like Andris' car).
Old 07-21-2004, 01:13 PM   #9 (permalink)
Rockwood
70/30 Racing
Rockwood's Avatar
Mike
they are $13.95 from summit mike. welding it is simple as well, as theyre not in an akward spot. the only extra step would be to strip the paint there and remove the windshield/weather stripping.
Old 07-21-2004, 01:22 PM   #10 (permalink)
choaderboy2
They have to be cut to fit from sheet stock and require removing the windshield. It would add several hundred dollars to a cage bill which can be the most expensive part of a cup car.
Old 07-21-2004, 01:30 PM   #11 (permalink)
Greg Amy
NX2000 Racer
Greg Amy's Avatar
..and then, when you open that can of worms, you've opened a ton of possibilities for other performance modifications. 'Cause I guarantee you, whatever wording you come up with to allow more than the eight points to the chassis, I can come up with many, many other performance mods to take advantage of it. I'll have a World Challenge Touring cage in that sucker faster than you can say, "uh, wha...?"
Unintended consequences, and all that...
Greg Amy is offline   Reply With Quote
Old 07-21-2004, 01:35 PM   #12 (permalink)
Rockwood
70/30 Racing
Rockwood's Avatar
true, true.
alright, so they're not legal, and wont be anytime soon.
Old 07-21-2004, 02:15 PM   #13 (permalink)
tpeele
You can buy precut gussets and you would only need to remove the windshield if you are welding one on both sides of the bar. Or you can just do it when you put your perfectly legal lexan windshield in. Of course they don't make one of those for the NX.
Tim
Old 07-21-2004, 02:18 PM   #14 (permalink)
tpeele
How is the wording in the SRX rules? Why not just allow gussets along the A pillar?
Old 07-21-2004, 03:10 PM   #15 (permalink)
Rockwood
70/30 Racing
Rockwood's Avatar
you can do this in SRX. not SR.
Old 07-21-2004, 07:50 PM   #16 (permalink)
Jim #98NX
Read the rules.
You can bring this up at the end-of-year rules discussion, but because it is an extra expense that doesn't add safety, just performance then it is not likely to fare well.
Just think all the existing cars would have to rip out their windshields to be competitive! No way.
© The SR20 Forum - Content from
