Go Back   SR20 Forum > Motorsports > Road Racing
Old 10-07-2004, 04:52 PM   #1 (permalink)
Shift_Munky
A.K.A. 2Fass240us
brake fluid level switch - keep or toss?
I will be doing some wiring cleanup in my engine bay and wondered how critical this is. It basically tells you when your brake fluid level is low, right? If so, I only trust most stock indicators as far as I can ejaculate them. If I check my fluid with regularity, would I really need it?
The car is a SRX-prepped S13, BTW.
240SR track donkey
Old 10-07-2004, 07:57 PM   #2 (permalink)
gsr20det
Side by side through 9
Keep it, that's a safety light. If it were a non-critical system like the ABS light or something I'd say dump it.
Tom Paule
#57 H4
Still own a P10
gsr20det is offline   Reply With Quote
Old 10-08-2004, 01:34 AM   #3 (permalink)
Jim #98NX
Traitor in your midst
I'd say keep it. Idiot lights = good.
-Jim
SE-R Cup Hooligan
Jim #98NX is offline   Reply With Quote
Old 10-08-2004, 08:07 AM   #4 (permalink)
Shift_Munky
A.K.A. 2Fass240us
OK, sounds good. I do have to keep a few things on that particular harness, so it wouldn't kill me to keep this one too. Plus, it's really close to the firewall, and should be easy to re-route if I decide to make any wiring changes.
Thanks for your input guys.
-Andy
Old 10-08-2004, 02:24 PM   #5 (permalink)
Creagach
Tired Greasemonkey
also comes on when battery or alt voltage is low.
keep it
Old 10-08-2004, 02:57 PM   #6 (permalink)
Jim #98NX
keep it
Good point- and there have been a few alternator failures in west coast racing.
Old 10-08-2004, 03:37 PM   #7 (permalink)
andris
fabricator
What kind of sissy-ass racecars are you guys building ? :-P
andris
andris is offline   Reply With Quote
Old 10-08-2004, 04:44 PM   #8 (permalink)
Jim #98NX
Get back to work you slacker!!!
Old 10-08-2004, 07:10 PM   #9 (permalink)
Shift_Munky
A.K.A. 2Fass240us
keep it
How does that work? The brake fluid level line switch will tell me when my alternator or battery voltage are low?
Old 10-08-2004, 08:06 PM   #10 (permalink)
Scarpa
Autox Junkie
He means the light is dual use. It tells you when the brake fluid is low, and also comes on (in conjunction with the battery light I think) when the voltage is low.
Honestly, I don't know if this is by design or a side effect of the mechanism by which the brake fluid sensor works.
Scarpa is offline   Reply With Quote
Old 10-11-2004, 02:33 PM   #11 (permalink)
Jim #98NX
It is by design. And eat your words Andris! John Lindsey in his #46 SE-R came in after the two lights (brake and battery) came on. He just swapped in a new motor prior to the event and forgot to tighten down the tensioner on the alternator.
Old 10-11-2004, 04:27 PM   #12 (permalink)
Shift_Munky
A.K.A. 2Fass240us
Wait...maybe I'm missing something, but how will removing the wiring for the brake fluid level sensor cause the light to not come on for low battery or alternator voltage?
Either way, it doesn't matter. I am leaving it hooked up. Although in all honesty, by the time the light comes on, the brake pedal would go to the floor, would it not?
Old 10-11-2004, 09:55 PM   #13 (permalink)
Jim #98NX
I believe it is designed to let you know when the fluid is low, not when it is gone.
I had mine come on when the resevior still had some left in it, but was below the "Low" mark. The brakes still worked.
Old 10-12-2004, 09:12 AM   #14 (permalink)
Shift_Munky
A.K.A. 2Fass240us
Ah...right. Maybe one of the more useful "dummy" lights then, eh?
I actually had this come on in my ITR once, but it was a false alarm because the fluid level was sufficient. Meh. I'm going to keep it on the S13 though. But the ambient switch isn't quite so lucky!
Old 10-12-2004, 10:10 AM   #15 (permalink)
chriscar
merely a flesh wound
chriscar's Avatar
Trader Rating: 97 (100%)
It comes on before the fluid is low enough to cause a problem. When the fluid level is barely too low, the body pitch and roll caused by acceleration, braking or turning will cause the fluid to slosh enough for the brake light to come on. It's most noticeable under acceleration when the nose of the car rises, causing the fluid to slosh towards the rear as the front of the master cylinder rises.
Old 10-12-2004, 11:16 AM   #16 (permalink)
Shift_Munky
A.K.A. 2Fass240us
Good call, C-Note. That mighta been the issue, except the light didn't go off until I shut the car off and restarted it. Probably just needed to be reset by the ECU after "alarm" condition was no longer detected...who knows?
And I drove the ITR like it was designed to be driven, so the slosh is very possible!
