Old 03-26-2005, 08:55 PM   #1 (permalink)
Calum
soylent green is people
Calum's Avatar
Approved vendor
Consult Kit Preview
I've gotten some questions about the status of this recently so I thought I'd post an update.
I got the ver 0 boards in a week and a bit ago, but made too many goofs on them for any to be saleable (mostly packaging, nothing electronics related). Too bad, I really wanted a couple of people to test out building a box on their own with one before ordering a large batch. Anyways, I finally got everything worked out and am about to order another batch (ver 1 now). Hopefully they shouldn't take long to test and put up for sale on the forum storefront. I'm aiming for having them in hand and tested by next weekend.
What will be included will be the board (unassembled) and one of the white consult-compatible-with-a-little-work connectors, while my supplies of those last. The other parts are available for purchase from www.mouser.com. I'll post the complete parts list and very detailed assembly walk-through too. They should be easy to build. Electronics parts total to IIRC ~$8.50, and the box I've picked out plus optional LEDs adds another $15-20, I don't remember exactly off the top of my head. The box is optional of course, you can put it in whatever you want, or nothing at all if you mount it in the car behind the dashboard or whatever (I mounted one on my test mule NX under the shifter console). The box I've designed it for however is nice, really nice. Anadized black extruded aluminium, it feels like a little brick. Really really sturdy, I think you guys will like them.
Here's the first ver 0 prototype completed. This one doesn't have any LEDs, the next one I make will. I've spec'd these neat little snap-in panel mount LEDs, they just came in Friday. This one is off for a new life with some bald dude in NY. Ver 1 won't use the plastic bezels on each end, I like the look of the box without them.
Here's what the box looks like unassembled. Its got integrated rails inside just for holding boards, sweet. You can order the box with either plastic or aluminium end panels. I like the aluminium, but plastic might be a little easier to work with.
Calum is online now   Reply With Quote
Old 03-27-2005, 02:32 AM   #2 (permalink)
JayLew
Garbage in Garbage out
Nice.
So we can just order them from the forums store? Sweet.
Jason
1992 240SX
2006 WRX (wingless non TR)
Old 03-28-2005, 05:01 PM   #3 (permalink)
blairellis
<>< Jesus Is The Answer
blairellis's Avatar
Is this compatible with any consult port? ie with a 240 and not just the sentra?
Blair
93 P10
Old 03-28-2005, 05:25 PM   #4 (permalink)
Calum
Calum's Avatar
Approved vendor
Yes, for the most part. Very early consult ports are not compatible, they use an onlder much more basic version of the consult system. All the 240s that came with DOHC KAs will work, the old SOHC ones won't. Your '93 will work just fine. If you've swapped a SR20DET into a 240 and swapped in the JDM ecu it will also work (any year 240), but you must have swapped in the wiring harness for it aw well. In other words, the JDM SR20DET ecu supports the consult protocol, but you must actually have a physical wiring harness with the consult plug wired correctly.
calum@calumsult.com
Old 03-28-2005, 05:28 PM   #5 (permalink)
blairellis
blairellis's Avatar
Gotcha. I know on my brothers 90 (sohc) we just taped the consult port wires out of the way on his swap. I couldnt find a place that described where they connect to. Any ideas consult master?
**Edited to include his year**
Old 03-28-2005, 06:07 PM   #6 (permalink)
Calum
Calum's Avatar
Approved vendor
When you say you taped the wires out of the way, was that from his old harness or part of the new harness? If that was part of the harness that came with the swap your probably good to go. If not, what you need to figure out is:
1) If he's got a consult connector, does it have the correct pinout. Compare his connector to yours, make sure the pins are in the same spots. If the pins aren't even in the right spots your going to have to make a custom harness to connect to the DET ecus consult port. Not a big deal, I can tell you what wires you need to splice (or just look it up in the B13 FSM, its the same for the DET ecu) and this gets you out of the headache of dealing with the consult plug so it will come out looking pretty dang spiffy too.
2) If the pins are in the right spots you need to figure out if the harness is connected to the right pins on the ecu. Look it up in an B13 FSM which consult pin goes to which ecu pin, its the same for the DET ecu.
Good luck.
Old 04-08-2005, 05:07 PM   #7 (permalink)
honkeybizkit
No D E T.
Trader Rating: 18 (100%)
Any Update on the kit? Ill be in for sure.
Jonathan Schultz
1992 Sentra SE-R
1997 200SX SE-R SOLD! **Now Replaced
2001 Lexus IS300
honkeybizkit is offline   Reply With Quote
Old 04-08-2005, 07:16 PM   #8 (permalink)
walrusx4
OMFG WTF BBQ
walrusx4's Avatar
so long as it's reasonbly priced, I'm in
~Dan @ Boston
99' G20t
Old 04-09-2005, 01:05 AM   #9 (permalink)
intiractive
Forever slow
so we just need this board thing with the connector wire from it to our laptop, and the program? sorry, im not too technical with computers.
#1 -1993 Classic XE SOLD
#2 -1992 Classic SE-R SOLD to Autoxse-r
#3 -1993 Classic SE-R SOLD
-2002 GMC Sonoma 4.3 V6 - The DD
-1988 Kawasaki EX500 - The newest money trap
Is it Possible to use a TMIC and FMIC?!?
intiractive is offline   Reply With Quote
Old 04-09-2005, 01:25 AM   #10 (permalink)
exxd
retired
It plugs into the consult port on one side and the laptop on the other and then you get the software
NOT SR20 POWERED
needs.
Old 04-09-2005, 06:33 AM   #11 (permalink)
STRATTON
i love b13's !
Trader Rating: 22 (100%)
calum that thing is deffinatly kick ass had one hooked up to my car the other day.
im back.......
Old 04-10-2005, 08:05 AM   #12 (permalink)
Calum
Calum's Avatar
Approved vendor
To everyone thats asked, they're almost there. Really really close, I'm just working on a photo shoot how-to now. Check out the forum store btw.
Old 04-10-2005, 11:47 AM   #13 (permalink)
walrusx4
OMFG WTF BBQ
walrusx4's Avatar
those look sweet calum
Old 04-10-2005, 12:40 PM   #14 (permalink)
FastNX
Professor Dingbat
Looking good. I will be ready to order as soon as you have these ready. You mention assembly of of consult box, what asembly is required? I'm not very good with this computer assembly stuff.
Also are the connections ECU>harness>consult port>consult box>PC? What I mean to ask is is the tuning done through the consult port?
Thanks,
eletronically stupid Jeff
Old 04-10-2005, 01:46 PM   #15 (permalink)
chriscar
merely a flesh wound
chriscar's Avatar
Trader Rating: 96 (100%)
You have the connection routing correct, but the Consult port is for monitoring only.
Old 04-10-2005, 01:58 PM   #16 (permalink)
FastNX
Professor Dingbat
OK, so how are changes made to the ROM? The burner connects to the port that is soldered in place by Calum?
Old 04-10-2005, 02:20 PM   #17 (permalink)
chriscar
chriscar's Avatar
OK, let me try and clarify this. There are two different things going on here. The consult port is for monitoring only. You connect to it using an interface box and software, like Calumsult, or ConZult.
To make changes to the program running in your ECU, you need an ECU which is modified with a daughterboard and removable eprom's. Next, you need an eprom burner which is a box that connects to your PC and allows you to read & write to the eprom.
Calum explains it in more detail HERE
Old 04-10-2005, 02:32 PM   #18 (permalink)
FastNX
Professor Dingbat
What confuses me is the tuning process. Basically what is involved in changing the values in the fuel and ignition maps.
Also when tuning, is the consult box connected to the PC or is that totally separate?
Old 04-10-2005, 02:59 PM   #19 (permalink)
exxd
retired
The consult box connects to the pc. When you need to change a value you make the changes in whatever software you are using, pull the 2 chips off of the daugherboard, stick them in your eeprom burner and burn the chips and put them back in. You can use the consult box to make some slight temporary changes or do test.
Old 04-10-2005, 03:02 PM   #20 (permalink)
