Old 04-01-2005, 03:18 AM   #1 (permalink)
micra_pete
MicraHolic
Roms in excel format - hope this helps
hope this helps someone.
bunch of popular roms (the main map area) in excel format, hex and dec, good for finding patterns, maps, messing with multiplication factors etc.
take care with the vvl files as i reckon the ecu uses a few different methods to the normal ecu, and it may also need some more of the rom adding.
but its a nice easy way to look at the roms.
good for finding maps
micra_pete is offline   Reply With Quote
Old 04-01-2005, 08:13 AM   #2 (permalink)
exxd
retired
sweet! thanks, did you enter this all in by hand or is there any easy way?
NOT SR20 POWERED
needs.
Old 04-02-2005, 09:50 AM   #3 (permalink)
micra_pete
MicraHolic
i wish there was an easy may, all done in the method used in my finding maps post.
also, im sure people have realised, but the hex number is wrong, ie the list from 8000, i just copied it across, just change the 8 to whatever number is needed
Old 04-06-2005, 06:46 PM   #4 (permalink)
Calum
soylent green is people
Calum's Avatar
Approved vendor
Btw Pete, this does help. I've got something from this I will post. Cool!
calum@calumsult.com
Calum is online now   Reply With Quote
Old 04-07-2005, 03:16 AM   #5 (permalink)
micra_pete
MicraHolic
is the the base idle map for the b13?
if it is i reckon i found it too......
if not, i'll fire my laptop up later and get the address, see what you think.
glad its helping someone
Old 04-07-2005, 08:38 AM   #6 (permalink)
Calum
Calum's Avatar
Approved vendor
No but do tell, I'll test that out.
Old 04-07-2005, 08:40 AM   #7 (permalink)
exxd
retired
I'll test too I have a great great great way to test.... ::kicks car::
Old 04-07-2005, 10:26 AM   #8 (permalink)
micra_pete
MicraHolic
baring in mind I don't own a sr20, and was just having a quick look last night whilst having a few beers
based on how it looks, and comparing to to the ga and cg values, if I could test the sr ecu I would try 0660
1500 1500 1500 1500 1500 1500 1500 1400 1300
1100 1000 900 800 800 800 1000
Old 04-07-2005, 10:28 AM   #9 (permalink)
micra_pete
MicraHolic
if its wrong its wrong, i'll continue having a look, i think i have found some other start up maps too, but i'll check at home
Old 04-09-2005, 01:58 AM   #10 (permalink)
exxd
retired
Hum so is this map based on temp? When you get a chance please post the other stuff too!
Old 04-09-2005, 08:25 PM   #11 (permalink)
Calum
Calum's Avatar
Approved vendor
660 is correct, cool beans. One caveat though, it seems there are multiple "idle" maps. It only switches to 660 if your dead still. If your barley moving (like slowly creeping to a stop) its going somewhere else because my idle drops back to ~800. More hunting.
I believe Chris suggested 660 first, I just never got around to trying it, silly me.
Old 04-10-2005, 02:47 AM   #12 (permalink)
exxd
retired
Ya i wasnt thinking its my coldstart that is messed up. I think its the temp sensor. Anyone find the cold start maps?
Old 04-10-2005, 03:11 AM   #13 (permalink)
eurospecs13
Do you mean the injector start pulse width table, if so I believe it is at 0320.
eurospecs13 is offline   Reply With Quote
Old 04-10-2005, 11:09 AM   #14 (permalink)
micra_pete
MicraHolic
calum i have a couple of areas to try, erm ignition idle, that sort if thing, i'll post some addresses tommorow.
Old 04-11-2005, 03:33 AM   #15 (permalink)
micra_pete
MicraHolic
right, baring in mind i dont have a sr20, nor access to any data logs, i've had a look, and i believe there are maps at the following location, they all seem "sensible" area's to try.
maps at
0A0-
0B0-
0C0- AF enrichment based on coolant?
0D0- AF enrichment based on coolant?
0E0- rpm scale fuel
0F0- tp scale fuel
200- acceleration increase volume
210-
220- revise crowded blast off temp
230-
300-
310-
320-
350-
360- Starting injector pulsewidth?
370-
380-
350-
360-
370-
380-
390- TTP min
3A0- TTP max
450-
460-
470-
480- rpm scale ignition
490- TP scale ignition
4A0- Ignition Advance (based on coolant)?
4B0- Ignition Advance (based on coolant)?
4FO- idle stabilisation control limit?
500-
510-
520-
660-
680-
690-
6A0-
6C0-
6F0-
7A0-
940-
960-
970-
980-
990-
9A0-
A00-
A40-
AC0-
F90-
FC0-
Old 04-11-2005, 04:18 AM   #16 (permalink)
micra_pete
MicraHolic
heres some cg stuff
maps at
080-
090-
0C0-
0D0-
120-
130-
150-
1E0-
1F0-
2C0-
2D0-
360-
370-
3B0-
3C0-
3D0-
3E0- fuel TP scale
3F0- Fuel RPM scale
500-
510-
530-
540-
550-
560-
570-
580-
590-
5D0-
640-
720-
730- Idle ignition map
740- ignition advance - coolant
750- idle stabilisation control limit
770-
780-
790-
7A0-
7C0-
7E0- ignition TP scale
7F0- Ignition RPM scale
900-
920-
980-
990-
9A0- base idle correction (based on coolant)
BA0- Starting injector pulsewidth
BF0-
C70-
CB0-
CC0-
CE0-
CF0-
on a side note, im hoping to have an access monitor in the next month or so, so hopefully should help to see whats going on a bit more
Old 04-11-2005, 10:04 AM   #17 (permalink)
exxd
retired
Awesome, is the base idle map @ 660 based on coolant temp?
Old 04-11-2005, 10:25 AM   #18 (permalink)
micra_pete
MicraHolic
i think so
Old 04-12-2005, 10:47 PM   #19 (permalink)
Calum
Calum's Avatar
Approved vendor
I've been working out where the maps are based on the routine that calls them. Theres a bunch, but not all seem to have much in them. Its depressing how many maps there are. We need to start a comprehensive document of all the maps, where they're called, what they do if known, and whats in the code near them if known.
Old 04-13-2005, 12:00 AM   #20 (permalink)
eurospecs13
what exactly is the revised blast off temp
Show Printable Version
