Old 04-29-2005, 09:31 PM   #21 (permalink)
www.FAIRTAX.org
paNX2K&SE-R's Avatar
Trader Rating: 66 (100%)
Cool! How bad is the harshness? I notice the same thing with my jwt program. The throttle is sorta jumpy when getting on/off at low speeds.
91 SE-R w/DET
02 G20 Sport 5spd
94 Miata "homobile"
93 240SX Family Project
Old 04-29-2005, 09:40 PM   #22 (permalink)
retired
I allways figured it was because the 4 counter-weight crank is sooo light. I have to be super careful at in 1st gear partial throttle (thats whiplash turf)
NOT SR20 POWERED
needs.
Old 04-30-2005, 12:42 AM   #23 (permalink)
the spookman
tell me about it just a few days after i got my car i found that out the hard way in the parking lot...people had hard time beleiving i could drive stick.
05 Legacy GT
93 NX2000 w/VE
(\__/)
(O.o )
Old 04-30-2005, 01:26 AM   #24 (permalink)
DVNO, 4 capital letters.
It is because of the ECU, because it does not happen with my JWT. The JWT also feels better driving around.
Old 05-01-2005, 12:19 AM   #25 (permalink)
the spookman
Arrrrg JWTs are so expensive.
Old 05-01-2005, 11:57 AM   #26 (permalink)
^^ I'm with stupid ^^
JRios's Avatar
Approved vendor
Do you happen to have the part number for that maf?
Care to share how you figured out the K value? TIA.
Jorge
1996 SE-R
Old 05-03-2005, 03:47 PM   #27 (permalink)
merely a flesh wound
chriscar's Avatar
Hey Calum,
Is your VE program expecting to see the US or JDM temp sensor?
My car idles at 2500 rpm when it's cold. I'm not happy with a cold engine idling that high with no load, so I usually just drive off. If I come to a stop within a few minutes of the car just starting, the idle hunts pretty radically. The warm idle is fine. I do have the water lines hooked up to the TB.
I should have datalogs for you this weekend after the dyno day. Looks like we're going to have a few VVL's there, including Kesi's 220+ hp VE. I'll try and get logs from all the cars.
Old 05-03-2005, 05:17 PM   #28 (permalink)
retired
Which TB did you use?
Old 05-03-2005, 05:20 PM   #29 (permalink)
chriscar's Avatar
VE TB, DE MAF, VE injectors.
Old 05-03-2005, 05:23 PM   #30 (permalink)
retired
Someone correct me if im wrong, im taking a leap on this one. Chris I think the VE throttle body has some sort of a mechanical cold idle. There is a allen head screw I think somewhere around there that you can adjust. I used the VE TB also but never got around to adjusting it.
Old 05-03-2005, 05:32 PM   #31 (permalink)
chriscar's Avatar
It does.
I will.
Thanks,
Old 05-03-2005, 05:35 PM   #32 (permalink)
chriscar's Avatar
The screw on the bottom.
Old 05-03-2005, 05:37 PM   #33 (permalink)
retired
How long the ecu stays in cold idle for can be messed with, is that what you were talking about way up there? ----^
I made some changes to mine so that it would come out of cold idle routine a little earlier.
Old 05-03-2005, 08:00 PM   #34 (permalink)
I want to have the boards and program done to my stock ECU. What is an aproximate turn around time?
NissanSpeed01 is offline   Reply With Quote
Old 05-04-2005, 07:45 AM   #35 (permalink)
soylent green is people
Calum's Avatar
Approved vendor
Trader Rating: 24 (100%)
The maxima MAF I got in has a pink sticker and is labeled p/n 22680-31U00, is this the correct p/n for the VE maf?
Edit: Nevermind, searched and it is.
Old 05-04-2005, 10:46 PM   #36 (permalink)
the spookman
Awwww shyte. I just looked at my mafs p/n and itrs 22680 16v00. The older style maf. From searching I think I figured out that it wont work with the one you tested. Oh well...looks like its a trip to the junkyard for me
Old 05-05-2005, 09:25 AM   #37 (permalink)
retired
It will work just fine.
Old 05-05-2005, 04:00 PM   #38 (permalink)
the spookman
woot! Any idea when this program will go into production for the Calumsult?
Old 05-05-2005, 04:11 PM   #39 (permalink)
Calum's Avatar
Approved vendor
CalumSult is software, not hardware. The hardware is just called a "daughter board". They are not directly related.
I'll put any program on a daughterboard you want (whether it works on not is your ball), but I suggest just buying a rom burner and trying out different programs. Its really really easy to do, thats what the daughterboards are really designed to do.
calum@calumsult.com
Old 05-05-2005, 09:29 PM   #40 (permalink)
retired
The VQ map for your MAF is sooooo close to the newer maf that it doesnt really matter.
I use the same maf. If you want to be a ricer like me you can tell people you have an rb20det maf from a late r31 skyline.... bling bling LOL but seriously it took me a week of research to pinpoint the VQ map because the R31 used a few diff. mafs.
