Measuring MAFs - PART I - SR20 Forum
Old 04-24-2005, 12:58 AM   #1 (permalink)
ClamSlut
Calum's Avatar
Feedback Score: 26 reviews
This is another little project of mine I've been meaning to write up for a while but just haven't had the free time. Part I discusses the test setup I used for the measurements (in detail in case any of you guys want to build something like it) and Part II is the results. Enjoy!
Ok, background: Routinely you hear people talk about "how big XXX MAF is" or "how much HP XXX MAF can measure", but these statements are just best guesses and only vaguely have something to do with reality. Realistically you shouldn't even be talking about sizing MAFs in terms of HP; HP is not a unit of mass flow. What should you be talking about when you compare MAFs? Units of mass flow, like gm/sec or lb/min (just like fuel injectors!).
So to clear the air of the smell of bullsh*t I started measuring the different common Nissan MAFs. To date I've measured the following: Stock DE, Stock GTi-R, Z32, and Q45. I'd like to get my hands on bored versions of the DE and GTi-R MAFs, and also the VE MAF. Its just a matter of time. Anywho, I had an ulterior motive in mind for this project too. A lot of you guys know the k-value has something to do with the ratio of the maf size to the injector size. Well, it turns out the k-value is exactly the ratio of MAF size (defined as the maximum measurable airflow) and injector size, both in units of mass flow, x 1000. Thus if you know the exact MAF size (and assuming you know the injector size) calculating the correct k value becomes significantly less guess work than it currently is.
So getting down to business, how do you measure the how much a MAF can read? Well, in a nutshell, hook the MAF up to some calibrated controllable airflow, monitor the output voltage of the MAF, and then step the airflow through a given range, resulting in nice table of voltage vs. mass air flow. If only it were as easy as it sounds. There are two big problems: first, you've got to have a calibrated source of air flow. In my case, I had this covered by already owning a precision anemometer of suitable range. More on this dude later. Quick side note, if your looking to build a similar test setup you've got two options: hunt eBay for suitable calibrated mass flow meter (new is very expensive) or use a stock MAF sensor based on the data I provide and live with the margin of error.
Second problem: your air source needs to be able to max out the MAF. This is tricky, your engine can flow a crap load of air, so the MAFs have a huge range (especially the big ones). Not having a way around this problem I cheated. We've actually already got a mass flow vs. voltage table: the VQ maps from the rom! However, they're not scaled (well, they are by the k-value, but without already knowing the answer we can't use that), so what we've got is the shape of the curve but no values. So what I did was measure the lower half of the curve (using a dust collector as my air source) and do a little curve fit to extrapolate the larger values. This adds some error, but this is ballpark stuff anyways.
Here's my test setup. From left to right: the dust collector (air source), a valve to adjust the flow, my flow meter, and finally the test MAF with power supply and multimeter (and I finally found a use for my old HKS mushroom).
Here's a shot of the valve I used to change the air flow. It’s just a simple slide valve. I placed it downstream of both air flow meters so any leaks don't add error.
Here's my Dwyer Anemometer. This dude is hot wire sensor just like our MAFs use but with no outer pipe. It also has a temperature probe in the tip, so it reads in standard velocity (m/s). If you know the diameter (and thus surface area) of your pipe you can convert this measurement to mass air flow. Note also the long pipe length on both sides of this sensor, the longer the better.
...and here's the end of the setup. Power supply, multimeter, and MAF sensor with mushroom filter. What’s not shown is the vacuum grease I used to seal each fitting. Any leaks contribute error, so everything needs to be nice and tight. Vacuum grease is wonderful for sealing connections but its pretty nasty stuff.
Operation of the setup is pretty straightforward: adjust the valve incrementally and record the MAF voltage and measured airflow.
I'll post Part II tomorrow, stay tuned!
Old 04-24-2005, 01:56 AM   #2 (permalink)
Forever slow
Feedback Score: 4 reviews
wow, now thats what i call dedicated. badass dude, keep it up. most of your previous work has been over my head, but i actually understand this and am interested. cant wait to see part 2.
#1 -1993 Classic XE SOLD
#2 -1992 Classic SE-R SOLD to Autoxse-r
#3 -1993 Classic SE-R SOLD
-2002 GMC Sonoma 4.3 V6 - The DD
-1988 Kawasaki EX500 - The newest money trap
Is it Possible to use a TMIC and FMIC?!?
intiractive is offline   Reply With Quote
Old 04-24-2005, 08:58 AM   #3 (permalink)
retired
Feedback Score: 9 reviews
Awesome, I have been wondering how you were going to set this up. Your workstation owns mine. Ill take some pics some time. I gotta pm you anyways.
NOT SR20 POWERED
needs.
Old 04-24-2005, 09:38 AM   #4 (permalink)
MicraHolic
well i was gonna ask about this, thanks calum.
seems obvious once its pointed out really.
btw you have access to really cool stuff.
micra_pete is offline   Reply With Quote
Old 04-24-2005, 01:21 PM   #5 (permalink)
No soup for you
Feedback Score: 30 reviews
Your setup reminds me of my days in the Navy working Comm/Nav at AIMD. You've got stock in some nice tools there.
John
B12 turbo madness
424 whp / 328 ft. lbs
2440 lbs. w/ a full tank
B14 VE Hotness
244 whp / 228 ft. lbs
Old 04-24-2005, 02:56 PM   #6 (permalink)
I love Katamari
Feedback Score: 3 reviews
cool,very cool - I eagerly await pt.2
save the whales, harpoon fat chicks
Bjorn is offline   Reply With Quote
Old 04-24-2005, 04:09 PM   #7 (permalink)
The Anal Rententive Tuner
dude you rock.
that is some test bench.
you need to visit the oracle to upgrade your black mage to a black wizzard.
FF I rules.
03 350z Performance
99 G20t, t = turbo - Sold
1993 SE-R - Sold
05 GTI 1.8T
classicser is offline   Reply With Quote
Old 04-24-2005, 10:49 PM   #8 (permalink)
ClamSlut
Calum's Avatar
Hang on, I suck at math tonight. Give me a bit more time on Part II. Stupid numbers.
Old 04-26-2005, 12:48 AM   #9 (permalink)
Garbage in Garbage out
Rough night with the MAFematics?
BTW, are you taking requests?
I have a spare KA24DE maf if you want to test it.
Jason
1992 240SX
2006 WRX (wingless non TR)
Old 04-26-2005, 03:17 AM   #10 (permalink)
MicraHolic
^^ thats really bad
Old 04-26-2005, 10:18 AM   #11 (permalink)
ClamSlut
Calum's Avatar
Man, thats bad.
Old 04-26-2005, 10:37 AM   #12 (permalink)
retired
lol ::taking up 6chars::
Old 04-30-2005, 04:49 PM   #13 (permalink)
That is an awesome setup, I was going to do something simular. However I was going to use my OBD-II logger and techtom mdm-100 to record MAF lb/min vs rpm and MAF volt vs rpm. The only thing is I need access to a B14 so I can get the datalog and compare.
91 Nissan Sentra SE-R: KYB AGX's, eibachs, prothane mounts, ES suspension bushings, addco RSB, FSTB/RSTB, CAI, JWT C2/ECU, 3in B-pipe, UR UDP, nitrous
Best ET: 13.57 @ 99mph
Nismo87SE is offline   Reply With Quote
Old 04-30-2005, 10:27 PM   #14 (permalink)
eric96ser's Avatar
Feedback Score: 29 reviews
Calum, the 3.3 Pathfinder MAF is the same part number as the VE MAF, so most salvage yards should have one.
The community is here.
Old 05-02-2005, 07:17 PM   #15 (permalink)
ClamSlut
Calum's Avatar
I ordered one. I need to update this thread.
I need to send you an e-mail too, but its been busy here. Want to still do the dyno thing sometime?
Old 05-02-2005, 08:19 PM   #16 (permalink)
eric96ser's Avatar
I need to find a time that works for a bunch of us.
Old 05-21-2005, 11:56 PM   #17 (permalink)
I just picked up a Q45 MAF a day ago. Care to share some info on in? <----if not, no problem.
Ive read that it can flow up to 480 whp. Which is exactly twice what my KA MAF suposedly can handle. So K * 2 right?
BTW, to bore out a DE MAF do you just remove the sensor and then have a machine shop bore it out to 53.3mm?
If so, Ill have my spare one bored out and Ill send it up to you. That is as long as the machine shop doesnt want an arm and a leg for it.
Old 06-02-2005, 03:32 AM   #18 (permalink)
Grandma's gonna get ya!
coalitionSE-L's Avatar
Feedback Score: 6 reviews
Calum, did you ever find out what the maximum flow rate is in lbs/min for a stock DE MAF?
1999 SE-L SR20DET-- Sold!
Old 06-06-2005, 08:53 AM   #19 (permalink)
4th sr20 and counting..
zipstrips's Avatar
Feedback Score: 21 reviews
i have access to a machine shop, if someone can confirm 53.3mm ill have my spare bored and shipped out for testing....
SHIFT_multiplication!
01. Audi TT 225
98. the zips machine
95. t28 setup
95. Celica, 3SGTE
90. Miata BP swap
Old 06-06-2005, 10:02 AM   #20 (permalink)
JWT says 53.3. Bore it to 54.
