Old 05-27-2005, 11:57 AM   #1 (permalink)
Whut?That Ain't No Hondah
Consult Interface won't connect anymore (not cable!)
So I purchased a consult cable thru plms about a year ago. It never worked in my 92 Sentra SE-R, but worked good in my Z. I sold the sentra, got a 92 NX2000. The consult cable worked like a champ for about a month. Then one day, *poof* it doesn't want to connect anymore. The cable still works good in the Z.
My ecu in the NX is a u12 BlueBird.
Any idea why it would just stop working? Should I trace the wires that run from the consult plug to the ecu?
1990 2+2 TwinTurbo 300zx
1993 NX2000 (JDM SR20DE-T)
1.6 to DET Swap
Engine Removal Writeup
NissanWar.Com - Pick the Nice from Rice
Like Boxing? Check out FightJudge.com
Crim is offline   Reply With Quote
Old 05-27-2005, 01:06 PM   #2 (permalink)
soylent green is people
Calum's Avatar
Approved vendor
Trader Rating: 22 (100%)
The old schematic plms had is flawed. so is their new one, and the NZ one. The new one (and the NZ one) have a cheesy fix, but it doesn't work very well on some ecus (namley B13/S13 ecus). I tried the exact same fix when I first ran into this problem, but discovered that its not that great of a fix. Symptoms are not working on some cars or crashing when trying to do something with lots of data transfer like dumping the rom. The old plastic boxes I sold had the same problem, the new metal boxes are fixed. This may not be your problem, but I'll bet dollars to doughnuts it is.
The fix I'm using now (and have been for the last yearish) seems to work with no problems on any cars. Its a much better fix.
I can repair or modify boxes, although depending on how the board is laid out it may be easier just to replace it. If you want me to take a look at it I'll send you my shipping address. If you want to try this yourself I'll post in detail exactly what the problem is, the not-so-good fix, and the better fix.
calum@calumsult.com
Old 05-27-2005, 01:59 PM   #3 (permalink)
I sent you a PM.
I thought I got the "new/fixed" designs from PLMS. I recall there being some issues being brought to light on twinturbo.net, and PLMS declaring that they fixed it, which is what prompted me to buy it. Maybe this is the cheesy fix you're refering too.
My cable does crash my software when doing rom dumps, so I'm willing to bet you are correct in your assumtion.
Old 05-27-2005, 02:14 PM   #4 (permalink)
not sure if its of any help but heres some shots of the board...
http://crim.darksci.net/pub/pics/consult/DSC00019.JPG
http://crim.darksci.net/pub/pics/consult/DSC00021.JPG
http://crim.darksci.net/pub/pics/consult/DSC00022.JPG
Old 05-27-2005, 04:48 PM   #5 (permalink)
Calum's Avatar
Approved vendor
Thats actually based on the original design, no cheese.
I hate surface mount stuff. If its got the usual problem I can fix it, but I'll have a be a little creative. Does that go in a box?
Old 05-27-2005, 04:52 PM   #6 (permalink)
yes its enclosed in a small black project/plastic box with two screws.
Old 05-27-2005, 04:55 PM   #7 (permalink)
Calum's Avatar
Approved vendor
Ok. I'll need to order one smt part, most of my stock is through-hole stuff these days.
Old 07-19-2005, 02:22 PM   #8 (permalink)
*bump* You get my PM about this?
Old 07-19-2005, 02:39 PM   #9 (permalink)
Calum's Avatar
Approved vendor
Yep, sorry. I'll reply tonight. If I don't send a reply within a day or two when you send me a PM just send me another, I will eventually reply.
