» Auto Resources
Find new Nissan car reviews on Nissan Maxima, Nissan 350Z, and more. View pictures and guides on Nissan cars like a Nissan Altima.
» Sponsor Links
»Garage Storage and Cabinets
Old 10-18-2007, 10:54 AM   #101 (permalink)
Yeah, sorry I overlooked the excel sheet descriptions. The chips are already there in the list.
I'll get the case ordered after I make a working one. Thanks for the link for connector.
Soravia is offline   Reply With Quote
Old 10-18-2007, 11:14 AM   #102 (permalink)
ClamSlut
Calum's Avatar
Approved vendor
Trader Rating: 24 (100%)
Those cases are pimpy, especially if you've got a DB9 punch or someone nice enough to cnc out the db9 spot. They're very rugged, more than strong enough to hold up in a garage.
calum@calumsult.com
Old 10-20-2007, 10:58 PM   #103 (permalink)
Did you get the paypal I sent for the board? Just checking since you seem busy enough without all the ECU stuff.
Old 10-21-2007, 08:54 PM   #104 (permalink)
ClamSlut
Calum's Avatar
Approved vendor
Yes.
Old 11-02-2007, 06:31 PM   #105 (permalink)
Thanks for the boards. Just waiting for the clock generator now.
Old 11-03-2007, 04:20 PM   #106 (permalink)
Is it OK if I use a Quartz Crystals
http://www.mouser.com/search/Product...559-FOX024S-LF
Instead of XO - Crystal Clock Oscillators
http://www.mouser.com/search/Product...-F1100E-245-LF
Old 11-03-2007, 08:39 PM   #107 (permalink)
no, normal crystal needs capacitors etc. get them from digikey or other, or wait for mouser
Originally Posted by Calum View Post
Alternates for the oscillator are available from Digikey (any of the following will work):
X105-ND
CTX105-ND
CTX142-ND
NewKleer is offline   Reply With Quote
Old 11-03-2007, 11:44 PM   #108 (permalink)
I made some improvement to your instructions.
I laid the capacitors and the voltage regulator flat so that they clear very well from the case and there is no need to cut the metal heat-sink from the voltage regulator. Which is good for hi-temp enviroments.
While laying down the Voltage regulator, put in some folded paper (two layer is good) between the voltage regulator and the chips before soldering the voltage regulator. This makes sure that voltage regulator won't be putting heat into the chips.
Old 11-16-2007, 11:31 PM   #109 (permalink)
Originally Posted by Tomcat5678 View Post
Alright, I had a little differences in my cables wiring compared to the colors posted by Calum. Here is what I found:
DB9:
Pin 1: Brown
Pin 2: Red
Pin 3: Orange
Pin 4: Yellow
Pin 5: Green
So on the consult it was like this:
Pin 1 = Consult 1 (Brown)
Pin 2 = Consult 2 (Red)
Pin 3 = Consult 7 (Orange)
Pin 4 = Consult 8 (Yellow)
Pin 5 = Consult 9 (Green)
Tie the bare ground wire to the yellow (pin 4) wire.
That is what I found, post up something if you found something else in your cable. I will be testing the mouser cables that I suggested to use above in this thread and post those results so if everyone just uses those than we can nail down a wiring color for all the needed pins so we cut down on confusion.
I have a DB-9 female to DB-25 Male cable cut. Pin out was
Serial 1 - Brown
Serial 2 - Red
Serial 3 - Orange
Serial 4 - Yellow
Serial 5 - Green
Ground - Ground loose wire.
My 91 model 240sx KA24DE has Pin out similar to Calum's. I'm guessing (actual try out will come tomorrow)
I tried to get the connection but ECUTalks can't read out.
Are there different pin outs from different Nissan Consult ports?
I have a KA24DE engine ECU from 91 240sx.
Old 12-20-2007, 03:48 AM   #110 (permalink)
Anyone know if i can use a ftdi usb interface to replace the outgoing rs232 and its chip?? Calum posted that if you are using a newer different st232 chip, you would have to use different caps or something. I was just wondering if using a ftdi usb interface would require you to change any components on the board.
undesiredshoe is offline   Reply With Quote
Old 12-20-2007, 04:09 AM   #111 (permalink)
if ur replacing the rs232 with the ftdi chip then you get rid of the rs232 chip and its 4 caps, so there shouldnt be any need to change it
Old 12-20-2007, 11:15 PM   #112 (permalink)
The 4 caps are used for the rs232 chip? Cool, so i dont have to use the 4 caps either? Im thinking its 4 of the .1uf caps?
Old 12-21-2007, 05:33 AM   #113 (permalink)
yes u can get rid of C3/C4/C5/C6.
though from memory u need a couple 0.1uf caps (one for 3v3out to gnd, other from vcc to gnd) for ftdi ft232r
Old 12-25-2007, 02:32 AM   #114 (permalink)
Cool thanks a lot. Ill use the rs232 chip for now so I know that the board actually works, then ill order the ftdi chip and see what i can do.
Old 01-15-2008, 12:26 AM   #115 (permalink)
Hey calum, do you think you can send me the schematic on the board itself. I want to see if I accidently bridged some traces on the board since i cant remember if there is suppose to be a trace that connects it.
Old 01-26-2008, 01:43 AM   #116 (permalink)
KA-t for life
hate to bug ya calum, i know ive already asked (afaik) but (or anyone out there) dont have any blank PCB's left do ya? i NEED a new consult adapter, and i dont feel like buying E-mances on ebay, when i can just make my own! maybe ill do like i did last time and just encapsulate the whole thing in hot glue
jmhalder is offline   Reply With Quote
Old 03-03-2008, 06:48 PM   #117 (permalink)
If anyone still selling just the PCB and/or consult plugs (completed would be nice) please PM me too~!
professorq is offline   Reply With Quote
Old 04-30-2008, 01:52 AM   #118 (permalink)
Hey do you guys have any more pcb or could i get the skimatic.
I am building a computer in to my car and this consalt cable would be amazing for it.
Haggis is offline   Reply With Quote
Old 04-30-2008, 03:28 AM   #119 (permalink)
schematic is in first post in thread
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
