Old 08-26-2005, 11:43 AM   #1 (permalink)
coalitionSE-L
Grandma's gonna get ya!
coalitionSE-L's Avatar
How to make an OBDII to OBDI adapter plug
I have just recently made a successful OBDII to OBDI adapter plug that allows me to run an OBDI (B13) ecu with a factory OBDII (B14) harness. There is no cutting of the factory OBDII harness necessary so reversion back to OBDII is simple if it is so desired.
This write-up will cover the process of making the adapter plug. I'd say the level of difficulty is moderate--especially if you are inexperienced with soldering--so leave yourself some adequate time to build the adapter if you are not proficient with electronics.
First off, here is a list of necessary parts, materials, and tools:
-An OBDI engine wiring harness. This can be from any 91-94 Sentra 91-93 NX, 89-94 240SX, 90-94 Pulsar GTi-R, 93-94 Altima, 89-95 Bluebird, or 91-93 G20. It does not matter if it came out of any of the aforementioned cars equipped with a 1.6, 2.0, or 2.4 because the ECCS plug is all you need off of it.
-An OBDII ECU. This can be from any 95-99 Sentra, 95-98 200SX, 95-99 Altima, 94-96 and 99 G20, or 95-98 240SX. Again the type of motor in these vehicles is insignificant since the plug is all that is needed from the ECU.
-Phillips and flat head screwdrivers.
-Dykes.
-Needle-nose pliers.
-Wire strippers.
-Soldering iron (pen style preferred) and solder.
-Solder remover (optional).
-Masking tape (optional).
-Electrical tape or shrink tubing.
-Two part epoxy (and lots of it).
-18 or 20 gauge wire.
Use the following pinout diagrams and excel spreadsheet (attached at the bottom) for this buildup.
Start by removing all the factory tape and loom from the vicinity of the ECCS plug on the OBDI harness.
Now you will begin cutting the plug from the harness. In the event that you want to possibly re-install the plug at a later date, number each wire with masking tape according to the pinout diagram before cutting it. This way, there is no question as to where the wire was pinned. Be sure to give yourself a sufficient amount of lead wire.
Now it's time to get a plug out of an ECU. I used a 1997 1.6 200SX ECU. It was donated to me by a friend of sr20sentra91 (Thomas). Big thanks to him!
Remove the ECU from its mounting plate and remove all screws from the outer casing, on top, on the sides, and on the bottom. This frees the circuit board from the case so you can remove the plug.
Now on the bottom of the circuit board, there are seven screws that need to be removed. Three of the screws go through the plug. These three screws have solder in them and can be removed one of two ways. If you have a solder sucker, remove the solder with that and simply unscrew them. However, if you are like me and do not have a solder sucker, these screws are quite simple to drill out.
Once the circuit board is free from the case, clip the wire that connects it to the body of the case.
You will see that on the back of the plug, there are pins that ninety down to the circuit board. Each pin is soldered to the board. If you have a solder sucker, you can use it to remove the plug. Once all the solder is removed, the plug will lift right off the board. However, if you do not have a solder sucker (like me), then you must clip each pin. The idea is to leave as much length on the back of the pins as possible, this will make soldering lead wires MUCH easier.
The easiest method when you are clipping is to remove any pins that you do not need right after they are clipped. This way you have more access to the trickier pins on the bottom of the plug. What I did was print out the OBDII pinout and black out the pins that I did not need (reference the Excel spreadsheet for this). This way, it was an easy visual reference. After snipping the back of an unneeded pin, simply bend it as straight as possible and pull it from the plug with needle-nose pliers.
When you are finished clipping all the pins, the plug comes right off. Here is a picture of the back of the plug.
-----Continued on next post-----
1999 SE-L SR20DET-- Sold!
Old 08-26-2005, 11:59 AM   #2 (permalink)
coalitionSE-L
Now your plug should have only the pins necessary to run the OBDI ECU. It is time to solder lead wire to each pin. 4-6 inches of lead is sufficient for each pin. This is kind of a tricky and time-consuming process, so be patient and take your time.
When you are done with all the leads, make sure to pot the plug with a 2 part epoxy that dries very hard. The solders on your leads will most likely not be extremely sturdy and the epoxy will ensure that the wires never seperate from their respective pins. Dam the plug up with whatever materials you have at your disposal which will do so and pour in the epoxy. You will use quite a bit of epoxy for this so make sure you have a lot. You may also want to block off the large slots in the plug so epoxy does not run down into the area where the ECCS plug connects. When you are done, it should look similar to this:
Next, it is time to connect this plug to the ECCS plug that you cut off of the OBDI harness. Using the pinout diagrams and the spreadsheet, connect, solder, and tape or shrink tube all of the wires to their respective "partners." Note that pin 50 on the OBDII plug connects to two wires on the OBDI plug. The (spl) in the spreadsheet means "splice." Note also that pin 45 may be missing from your OBDI plug, in which case you will have a leftover wire on the OBDII side. This is not a problem. It is easiest to do this wire soldering one side at a time.
When you are done, your plug should look similar to this:
Congratulations, you are done! It is plug-and-play from here. Simply plug your factory harness into the OBDII side and plug the OBDI side into your OBDI ECU.
Old 08-26-2005, 12:08 PM   #3 (permalink)
coalitionSE-L
I'd like to add that this spreadsheet does not provide for the data link plug for CONSULT. There are currently some folks working on that info, and I'm sure they will share when they are done. I was not concerned with my CONSULT plug because I am running a standalone on my car.
Old 08-26-2005, 02:01 PM   #4 (permalink)
gatr13
Best of both world's!
Trader Rating: 17 (100%)
Craig, is there any way we can put this thread in the turbo section or somewhere for all to see. Some viewers cannot get into the the contributor's section to view this great piece of work...
1996 200SX SE-R: Is Now GTIR POWERED!!!
Project Complete!!!Click Me!
Roastedpavement
Floridasr20s
gatr13 is offline   Reply With Quote
Old 08-26-2005, 02:09 PM   #5 (permalink)
coalitionSE-L
Originally Posted by gatr13
Craig, is there any way we can put this thread in the turbo section or somewhere for all to see. Some viewers connot get into the the contributor's section to view this great piece of work...
Yeah, I'll be adding it or having it moved to the tech info library, just wanted to post it for those interested here first since it was a hot topic here for the last week or so.
Old 08-26-2005, 02:13 PM   #6 (permalink)
nissanboi
sr20s are leet skeet
nissanboi's Avatar
great work so now we can use the plug and play aem corect¿
nissanboi is offline   Reply With Quote
Old 08-26-2005, 02:40 PM   #7 (permalink)
coalitionSE-L
Yes, you can use the 30-1600 (OBDI style) box on a B14. However, AEM does make a box for the OBDII style plug, but the 30-1600 is the box that runs the Bluebird/GTi-R maps. I just happened to buy my EMS back before the OBDII style box was released.
Old 08-26-2005, 03:37 PM   #8 (permalink)
Big John
No soup for you
Trader Rating: 30 (100%)
Very pimp. I'll be doing this over the weekend, I think. I'd like to put a Bluebird ECU on the VE-T and see how it does.
Regards,
John
B12 turbo madness
424 whp / 328 ft. lbs
2440 lbs. w/ a full tank
B14 VE Hotness
244 whp / 228 ft. lbs
Old 08-26-2005, 03:55 PM   #9 (permalink)
exxd
retired
Regards,
John
What about a daughterboard ecu
Old 08-26-2005, 04:03 PM   #10 (permalink)
Big John
No soup for you
I may eventually go that route. I'm just trying out different things.
John
Old 08-26-2005, 04:10 PM   #11 (permalink)
exxd
retired
Sounds good, I'm going outside to map out the consult wires be back soon
Old 08-26-2005, 04:28 PM   #12 (permalink)
exxd
retired
B13 ecu side:
pin 7 - tx
pin 15 - rx
pin 23 - clk
Old 08-26-2005, 06:19 PM   #13 (permalink)
JRios
^^ I'm with stupid ^^
JRios's Avatar
Hey, I just finished mine up today. Everything works flawlessly. Thanks alot for the help Craig!!
Jorge
1996 SE-R
Old 08-26-2005, 06:35 PM   #14 (permalink)
Setzer
DVNO, 4 capital letters.
Wow thanks for the info!
Old 08-26-2005, 06:38 PM   #15 (permalink)
daveracer
PLAY MY HEAD, MONKEY!
daveracer's Avatar
Trader Rating: 89 (100%)
I'm gonna do this asap.
Just found out my friend is giving me his obd1 KA harness plug. YESSS.
Old 08-29-2005, 10:13 PM   #16 (permalink)
daveracer
daveracer's Avatar
So ya, the KA24DE plug has no wire coming out of pin 23. Just an FYI.
Old 08-30-2005, 01:27 AM   #17 (permalink)
coalitionSE-L
I believe you can order pins through AEM. That way you can insert your own pin.
Old 08-30-2005, 04:08 PM   #18 (permalink)
Rob
VQ35 Powa!!
great write up!
Old 09-03-200
