Well, the difference is about $15 or so to keep it through hole. Not a big deal unless you wanted to do production, so through hole it is.
Calum,
I see. I change my mind then I rather have surface mount and save the $15/ea. I have been trying to work with Matt to get these available for the forum store, so the cheaper the better, as I can do surface mount no problem
i doubt the majority of people would be capable of soldering surface mount successfully with their current hardware (hence $15 more would be better than forking out $50 for decent surface mount soldering iron?). after making my own diy kit, i know for most people, thru-hole is enough trouble.
alternative would be to pre-solder the surface mount component so people wouldnt have to do it themselves.
see if you could fit all the smt stuff under the dip28/32 outline (since its raised), then you could have either on the same board? how many supporting components does the smt cp2102 need?
The through-hole will be based on the ever popular dlp-usb232m board, available from mouser for $25 in small quantities:
The smt will be based on slilcon labs cp2102, which in small quantities is $4.53, also from mouser.
have you made any progress with this?
i got myself some of the new FT232RL ssop28 chips, which are integrated solution (similar to cp2102) but able to be hand soldered (with difficulty ) however, while loopback works (hooking up tx to rx) i cant seem to get it to reliably read from the consult transmitter. it may be due to my circuit, but the circuit has had no issues at all with a max232 and a microcontroller reading from the same point.
what i get is its able to read it generally ok, but maybe 20% of the data comes back all garbled (eg just streaming 5A 00, ill get say FF 01 00 about 10 times, then ill get it dropping a byte, or getting the value of the byte wrong, and then eventually it goes back to normal, then does it again.
at this stage the only thing i can think of doing to get it to work is to use 2 max232's between it (rather than being able to omit those). would these chips be expecting something different on their receiver pins, something different to the max232 or a microcontroller? ive followed their sample circuits and doubt ive hooked it up wrong at all.
