Consult connection - SR20 Forum
Old 11-26-2005, 10:30 AM   #1 (permalink)
Just LTrain Again..
Feedback Score: 8 reviews
Consult connection
Well,
I tried using my new consult box (new version board). I am using Conzult freeware and calumsult. I managed to get this wroking on a friend's 92 SE-R. However I cannot get it to recognize my 94 and my brother's 93.5 G20. I this a common issue?
I tried updating COM port drivers and playing with the software and such to accomadate for ports. No such luck. Anyone with tips or insight? Please chime in.
-L
VVL
Former '94 SE-R w/ VE owner....made Chriscar a deal he couldn't refuse.
"Relax, alright? My old man is a television repairman, he's got this ultimate set of tools. I CAN FIX IT."
VVLtrain is offline   Reply With Quote
Old 11-29-2005, 10:42 AM   #2 (permalink)
jo mom
Wow, no luck on this? I wonder why it only worked on my 92 Classic. Maybe I should buy it off you since it only works on my sweet ride.
- 92 SE-R white, ES mounts, HKS catback, Random Tech cat, Revolution wheels
-2001 G20 silver
Andy92RubyClassic is offline   Reply With Quote
Old 11-29-2005, 05:35 PM   #3 (permalink)
Just LTrain Again..
GARRR!!!! NO! I want it to work on MY SWEET RIDE. Anyone? Bueller?
-L
Old 11-29-2005, 07:59 PM   #4 (permalink)
Feedback Score: 9 reviews
It should be the same as the PLMS one I think.
There's a list of applications on their site. Here's the US ones:
# US 300Z Z32 (VG30DETT)
# US Sentra B13 SE-R(SR20DE)
# US NX2000 (SR20DE)
# US NX1600(GA16DE)
# US '94 Sentra B13 (GA16DE)
# US Maxima A32 (VQ30DE)
# US '93 Altima (KA24DE)
http://www.plmsdevelopments.com/consult_if.htm
"As a rule if your car has the grey Consult connector (you'll usually find it near the fusebox) then it will probably work. One car we've heard of that DOESN'T have the Consult port is the A31 Cefiro - so if you've got one of these babies you best check the connector."
jp314 is offline   Reply With Quote
Old 11-29-2005, 09:22 PM   #5 (permalink)
Just LTrain Again..
Well both cars ('94 se-r/93.5 G20) have the grey connector in the fusebox they plug right in. Both cars are OBD 1 I assume. The '94 se-r was a low port even before the VE swap and the 93.5 G was originally highport but now has a recently swapped JDM 10:1 (still highport). Just for kicks, I tried it on a neighbor's 95 maxima (Cefiro) which also plugs in fine but no recognition.
Any ideas?
-L
Old 11-29-2005, 09:23 PM   #6 (permalink)
Just LTrain Again..
Oh one more thing... Could software play a part in it not reading? I am thinking not but I thought I'd ask.
-L
Old 11-30-2005, 12:47 AM   #7 (permalink)
now on the West side!
NismoSER's Avatar
Feedback Score: 17 reviews
Come down to Jackson man! There are like 6 different Nissans that you could try it on...my SE-R included
Chris
'91 VVL-powered SE-R SOLD
'04 G35 6MT
Old 11-30-2005, 01:57 AM   #8 (permalink)
How do the LEDs look when you hook it up?
RobertspecV is offline   Reply With Quote
Old 11-30-2005, 09:23 AM   #9 (permalink)
Just LTrain Again..
Well, on all the cars in which it plugs into, one led is always on. (I believe it was the Green one or was it the red one??) I do know that when the consult does work, the Yellow LED is on too. On the cars in whichit didnt work, the yellow LED very faintly blinks as soon as you click a command on the software (Idle adjustment mode in Conzult etc.) Also, it will show the ECU model # on the software if it recognizes it. Obviously doesn't do this on the cars it doesnt sync with.
-L
Old 12-01-2005, 01:24 AM   #10 (permalink)
Weird. If it works on some cars it should work on them all.
Are you using the same computer?
Old 12-01-2005, 09:46 AM   #11 (permalink)
Just LTrain Again..
Yes. Same computer.
Old 12-02-2005, 09:42 AM   #12 (permalink)
Just LTrain Again..
(crickets) *chirp chirp*
Old 12-05-2005, 10:48 AM   #13 (permalink)
Just LTrain Again..
One more thing. The consult doesnt work on another friend's 93 either.
Old 12-05-2005, 11:07 AM   #14 (permalink)
PLAY MY HEAD, MONKEY!
daveracer's Avatar
Feedback Score: 93 reviews
I don't think it's the cable because i tried it on both my 91 SE-R and 96 SE-R and they both work fine. I also tried it on a 99 G20, and it DIDN'T work.
Old 12-05-2005, 11:09 AM   #15 (permalink)
daveracer's Avatar
Do you want me to forward the datascan software to you to see if it's the software?
Old 12-05-2005, 11:23 AM   #16 (permalink)
Just LTrain Again..
I would love it. Send away please.
Old 05-13-2006, 02:12 AM   #17 (permalink)
Living up Boost
Did you get it working....just curious? And if so, could you please explain. Thanks
-saaby
Saaby is offline   Reply With Quote
