Attn gatr13 - gtir 444/z32 maf - SR20 Forum
Old 02-18-2006, 09:56 PM   #1 (permalink)
ClamSlut
Calum's Avatar
Feedback Score: 26 reviews
Bobby, I've been trying to e-mail you but haven't got a response. I have your ecu done and ready to ship (I've had it done for a week), but have question. You wanted a gtir tune with a z32 and the 444 injectors at 3.5 bar. Why 3.5, why not 4?
I'll post the tune Monday for everyone else to make this post worth something.
Old 02-19-2006, 12:47 AM   #2 (permalink)
Best of both world's!
Feedback Score: 17 reviews
I haven't received any e-mail. Did you try to PM me, I have been getting those from others. Would 4bar be too much? I had searched and asked around and was told that 3.5 bar would be good, is it not?
-Bobby
1996 200SX SE-R: Is Now GTIR POWERED!!!
Project Complete!!!Click Me!
Roastedpavement
Floridasr20s
gatr13 is offline   Reply With Quote
Old 02-19-2006, 01:30 AM   #3 (permalink)
Feedback Score: 7 reviews
The higher pressure of 4 bar is better for fuel atomization. As long as he adjusts the a/f map I dont see any reason 3.5bar is different than 4 bar.
Clean a$$ hell red 200sx.
Old 02-19-2006, 04:49 PM   #4 (permalink)
ClamSlut
Calum's Avatar
Bobby: Sorry, I don't use PMs. For some reason both e-mail servers I use must have problems sending to yahoo.com accounts. On the ecu: the thing you don't loose anything running at 4 bar versus 3.5 bar, so you might as well have the extra injector size. The Z32 maf should outflow the injectors, even at 4 bar. Thats a good setup, you'll have plenty of legroom with that combo.
Killdannow: Actually the neat thing about the way Nissan ecus work is you don't have to touch the fuel map when you resize for different injectors. The fuel map is a multiplier, not a specific injection time. There's a master variable ("k") thats you adjust for the injector size (and the maf size too). The fuel map adjusts the injection time calculated with your k-value by a given percentage (the percentage is whats actually in the fuel map), so hence changing injectors doesn't require changing the fuel map. Note: when you change injectors you also have to change the latency value for the injector, but because he's running stock injectors just at a higher fuel pressure the latency value is the same as stock.
Old 02-19-2006, 10:45 PM   #5 (permalink)
So did you program it for 4bar, if so that will be fine with me. Also, what is the redline set up for, 7500?
Old 02-20-2006, 05:57 PM   #6 (permalink)
ClamSlut
Calum's Avatar
Its programmed for 4-bar, redline is 8k.
Old 02-20-2006, 07:38 PM   #7 (permalink)
ClamSlut
Calum's Avatar
Bobby: FedEx tracking number 045739258199923
Galen: FedEx tracking number 045739258199961
edit: Galen, paypal me $50 to calum@calumsult.com sometime please.
Old 02-20-2006, 08:12 PM   #8 (permalink)
hadnt heard from you, didnt know what was going on. Payment sent, thanks calum.
Old 02-20-2006, 08:16 PM   #9 (permalink)
ClamSlut
Calum's Avatar
No problem, let me know how you like the ecu.
Old 02-20-2006, 08:22 PM   #10 (permalink)
what prog did i get?
Old 02-21-2006, 12:22 AM   #11 (permalink)
Thanks Calum, I'll let you know when I receive it.
Old 02-23-2006, 01:09 AM   #12 (permalink)
Hey Calum, Thanks! I received my ECU yesterday. I'll let you know how everything works out when I get my swap done.
Old 02-23-2006, 01:38 AM   #13 (permalink)
do i get a tracking number? and what prog did i get? whine whine whine.
Old 02-25-2006, 03:08 AM   #14 (permalink)
ClamSlut
Calum's Avatar
Sorry, missed your reply. Your tracking number is above. You got the standard NA program, I'm not sure what I called it when I uploaded it here (NA4?). It will run just fine.
Edit: FedEx says you got the package, yes?
Old 02-25-2006, 06:50 PM   #15 (permalink)
yep i got it thanks.
Whatsup, now your selling them with serial cables coming out ?!?!?
Old 02-25-2006, 07:14 PM   #16 (permalink)
ClamSlut
Calum's Avatar
Not quite yet, almost. I'm in the middle of beta testing, then they will be ready for full resale. I haven't got prices set for them yet either.
