LiveEdit + some more stuff
Hey guys, I know that liveedit won't work with the Moates burner, but I like the interface and I'm trying to find a way to load the bin I've created in Romedit, and view all the values in LiveEdit.
Using the s13 sr20et ini file available for Liveedit shows that all the address locations are in the same place, all I had to do was change the injector size. What I really need to figure out how to do is create/modify a air flow meter .bin file so that it matches the right stuff for a b13. Anyone able to help?
I'd like to figure out how to change the knock sensor values in romeditor as well (what values are in closed loop and which are not).
Then in Calum's sr20v2 with emissions, it looks like the rev limits are backwards. Limit 1 is the theoretical value, and limit 2 is the crazy high one.
ninja edit: oh and does calumsult datalog o2 sensor readings? If not what do I need to do so?
Thanks
Nick
