If you are having idle/limp mode issues. - SR20 Forum
Old 03-12-2006, 10:44 PM   #1 (permalink)
retired
Feedback Score: 9 reviews
If you are having problems with your car idling and then going into limp mode, Post your .BIN file here with a short description.
NOT SR20 POWERED
needs.
Old 03-12-2006, 11:48 PM   #2 (permalink)
retired
I should have a solution. Back out for testing I go.
Old 04-23-2006, 09:42 PM   #3 (permalink)
Best of both world's!
Feedback Score: 17 reviews
Any update on this. My car is finally running, but it's not 100%. At idle it's on the rich side, and when it get's into boost it starts to lean out (not good). So I drove it around staying out of boost to see if the ecu would correct itself. I don't think it's running as lean as the wideband is reading, because it's sucking gas like crazy. Help!
1996 200SX SE-R: Is Now GTIR POWERED!!!
Project Complete!!!Click Me!
Roastedpavement
Floridasr20s
gatr13 is offline   Reply With Quote
Old 04-24-2006, 01:22 PM   #4 (permalink)
retired
This thread was for the people that have the car go into limp mode at random during idle.
Sounds like your tune is off bigtime
Old 04-25-2006, 01:18 AM   #5 (permalink)
Mine was going into limp mode. I had to get another ecu and daughterboard setup from Calum to correct the problem. The one I have now has a 64 on the cover. Do you know of anyone running a Calum ecu in their GTI-R?
Old 04-25-2006, 01:26 AM   #6 (permalink)
now on the West side!
NismoSER's Avatar
If I had a way to pull my .BIN off of my eproms, I would. I've been through so many iterations with Calum, its just silly.
Chris
'91 VVL-powered SE-R SOLD
'04 G35 6MT
Old 04-25-2006, 02:07 AM   #7 (permalink)
retired
If the car is going into limp mode after idling for a few minutes thats the base rom. If the car is leaning out in boost and rich at idle the K and Lag time are off.
I have not done a db ecu on a gtir det yet.
Old 04-26-2006, 06:47 PM   #8 (permalink)
ClamSlut
Calum's Avatar
Feedback Score: 26 reviews
Bobby:
Your not the first gti-r but you are the first with that maf/inj combo
Sounds like what Nate said, my K and latency are out to lunch. Have you got a rom burner yet? There's a really good thread on how to set them up on a different forum, but I can't find it right now. Erm. In a nutshell:
-set your feedback to 00
-set your TTPmin to 0 and your TTPmax to 255
-set your entire fuel map to 1 (do not drive the car hard like this!)
-run the engine to ~3k and adjust the k value until the afr is around 14.7:1
-let the engine idle and adjust the latency until it idles around 14.7:1
-drive the car, staying off throttle and 4k rpm max, adjust k for 14.7:1
-replace tables and feedback with their original values (make sure to turn on feedback and include the feedback in the fuel maps)
-adjust tables so under boos performance is where you want it. For yours, this will mean adjusting the last two columns of the fuel map only.
-Post results to forum
With just a rom burner this is a long process (an emulator makes adjusting the k-value around quick), but you can do it in a weekend and you only have to do it once.
Old 04-26-2006, 06:48 PM   #9 (permalink)
ClamSlut
Calum's Avatar
I think I've got that cracked, got a rom burner yet? If not shoot me an e-mail and I'll remember to send a set of roms your way the next time I ship stuff out.
Old 04-30-2006, 07:32 PM   #10 (permalink)
No, I don't have a burner yet. Looking into getting one though. Thanks for all the info, Calum. Did you receive the other ecu back yet?
Old 05-03-2006, 09:41 AM   #11 (permalink)
NismoSER's Avatar
Thanks Calum. Email sent.
