What is the base idle AFR Calum uses - SR20 Forum
Old 03-14-2006, 08:53 PM   #1 (permalink)
For initial tuning purposes with a wideband, what should the AFR be at about 1000 rpm and 0% throttle.
1992 G20: JDM SR20DE Motor Swap, Avenir Manifold, Avenir T-25 (for just a little longer), FMIC, Hotshot IC piping, JWT ECU, SAFC-II, JGY 8.8 pound flywheel, JGY 6 Puck Clutch, Autometer Gauges.
gizzmo5580 is offline   Reply With Quote
Old 03-14-2006, 10:52 PM   #2 (permalink)
Formerly 93veilside240sx
Feedback Score: 10 reviews
Mine usually reads ~20.x on my Zeitronix wideband.
-'01 Cobra
-'93 240sx
-'71 240z
MarcTheNarc is offline   Reply With Quote
Old 03-14-2006, 10:59 PM   #3 (permalink)
retired
Feedback Score: 9 reviews
idle? 14.7:1
93viewside240sx.... 20:1afr? Does your idle lope?
NOT SR20 POWERED
needs.
Old 03-15-2006, 12:12 AM   #4 (permalink)
nope, my idle is fine
Old 03-15-2006, 12:17 AM   #5 (permalink)
retired
So you idle at 20:1afr and the idle is fine? Is the wideband calibrated?
Old 03-15-2006, 12:24 PM   #6 (permalink)
Its brand new, just installed it last weekend.
FWIW, I only have the upper part of my Protech downpipe installed right now, the J-pipe. This places the O2 sensor pretty damn close to the end of the exhaust, about 6" from the open atmosphere. I'm thinking that's why its reading like that. As soon as I hit the gas it drops down to where it should be. I haven't driven it since the wideband was installed, I simply installed it, started the car, gave it a couple revs to make sure the EGT and everything was working properly, and then shut it off.
Old 03-15-2006, 03:45 PM   #7 (permalink)
retired
Ah ok that makes a little more sense.
