Chris--
With the T28, you will make the same power numbers at lower PSI settings. Don't forget that. 300whp isn't enough? Throw in some cams. You will still be on that ragged edge with the 370s, no matter what fuel pressure you run them at. All it will take is one good ping and you'll crack a ring land, or do similar damage.
Long story made short: Get the T28, lower the PSI setting, make the same (and more) power, don't blow up, enjoy your 270-280whp and be done with it. Things get expensive from that point forward.
IMHO.
Greg Perry
Huntington, WV
-'93 SE-R, 12.80 @ 110mph
The car: '93 SE-R with a VE
