Calum: 99 SE-L calumsult question - SR20 Forum
Old 05-12-2006, 08:14 AM   #1 (permalink)
Living up Boost
I tried to send you an email Calum, but it keeps getting bounced back because my damn ISP is blacklisted for having so many spammers....
Ok. So long ago I asked you this:
"So since I have a 99 Sentra SE-L with a 97 200sx SE-R ecu, I can use the Calumsult software even though I have the Consult II port???"
And you replied:
"I don't know if the pinout of the consult II port is the same as the consult I, you would have to check."
This was the only question holding me back from being able to run Calumsult on my car...well, I think this question is answered. I was able to connect a TECHTOM MDM-100 to my consult plug and have it run and detect all my sensor info. Does this not verify that the consult I plug is the same pinout as a consult II plug since the MDM-100 also works in my friends S13 which has a consult I plug???...SOO, to recap:
1. I install Calumsult on a laptop with a serial port and running Windows XP Professional.
2. I assemble/purchase a consult box and serial cable.
3. I connect the consult box to my consult II port.
4. I connect the serial cable between the consult box and the laptop.
5. Run Calumsult and I'm good to go.
Right?
-saaby
Saaby is offline   Reply With Quote
Old 05-12-2006, 05:45 PM   #2 (permalink)
ClamSlut
Calum's Avatar
Feedback Score: 26 reviews
Yes to all of the above.
