Fixed Erich's Disasm, hopefully - SR20 Forum
Old 05-18-2006, 06:05 PM   #1 (permalink)
ClamSlut
Calum's Avatar
Feedback Score: 26 reviews
If anyone here cares, I think I fixed Erich's Disasm program (this was my C++ problem from a while back). This seems to perfectly disassmble the roms (program is posted at the end of the thread below, for some reason I can't add attachments here anymore). Assuming this is a good fix, it just needs to be rewritten to handle nested JSRs and its done, but Nissan didn't use any nested JSRs in the roms I tested so it will work as is.
If anybody else can test it on roms and scan through the output for correctness that'd be cool.
Anybody up for really wading through the rom?
http://eccs.hybridka.com/viewtopic.php?t=75&start=30
Old 05-18-2006, 08:16 PM   #2 (permalink)
Charlie Brown look alike
Feedback Score: 23 reviews
Congrats! Calum. I'll let the guy at work know.
Peanuthead is offline   Reply With Quote
Old 05-19-2006, 09:22 PM   #3 (permalink)
ClamSlut
Calum's Avatar
Ok, so it did need to handle multiple stages of JSRs, I was wrong. So I've posted a new version on the other thread. This version does recursive handling of JSRs, and points out suspect disassembly when it gets done. It also gives you something to look at as it chugs along, and sticks the result straight in a file. New run mode:
*** binfile index(8000) outfile
This version will b*tch about some spots, and for some bins produce a runtime error (just hit ignore, it should keep going), but the resulting disassembly looks perfect. Also, I compiled in Visual C++, which probably means if you don't use .NET it will hose you. For some reason when compiled with Bloodshed's Dev++ the output hangs half way through. Meh.
I suspect some of the comments (the call from and tos) might be incomplete, but otherwise the disassembly looks really good. Erich did a good job with the original version.
