How to change idle rpm? - SR20 Forum
Old 06-06-2006, 04:06 AM   #1 (permalink)
src
Hello guys!
I have a highly modified SR20DE w 12:1 compression ratio, and some aftermarket cams, so I need to change my idle rpm value. I'm in process of buying JWT C3 cams, so I really need to set my idle rpm to something like 1300 or 1400...
I have dautherboard in my ECU, I have EEPROM programmer, so I can change it by myself. Who knows how to change this?
Thank you!
src is offline   Reply With Quote
Old 06-06-2006, 08:28 AM   #2 (permalink)
ClamSlut
Calum's Avatar
Feedback Score: 26 reviews
The idle table is at $0660 on a B13/S13 ecu. The value * 12.5 = idle, and the table is referenced vs coolant temp.
Add these lines to a Rom Editor adr file:
#Add.map7
ADD_MAP7,&H0660,16,1,16,1,Idle map
So for a 1400 idle just raise the smallest values in the table to 112 in Rom Editor.
Old 06-06-2006, 04:12 PM   #3 (permalink)
src
thanks, Calum!
I found that map!
I see just 2 additional maps (plus idle map) in my current romeditor's config...
Is there are any additional maps available, which I need to know?
I want to know everything about my ECU!
Old 06-07-2006, 08:41 AM   #4 (permalink)
ClamSlut
Calum's Avatar
Lol, that depends. There are about 50 maps in a B13/S13 ecu, but most of them you can leave alone. It depends on what your doing.
Old 06-07-2006, 08:45 AM   #5 (permalink)
merely a flesh wound
chriscar's Avatar
Feedback Score: 110 reviews
Calum, we need to setup a WebEx meeting or something so you can give us a live class on this!
Old 06-08-2006, 03:28 AM   #6 (permalink)
src
Calum, it's great! Can you just describe a little these maps?
Or just give us an addresses with short description, in the form as you gave me idle map adress:
#Add.map7
Thank you a lot!
Old 06-12-2006, 04:35 AM   #7 (permalink)
src
Calum, one more question.
How can I change ignition advance at idle rpm?
I hear an opinion what here is an additional map in B13 ecu to control idle ignition advance.
Or I will just chage it at ignition map for corresponding RPM?
