USB to Serial adapter = dump problems?
Using Calumsult .07 I was unable to get a complete rom dump using a modern, powerful laptop with a USB to Serial adapter, yet I had no problem dumping the same ecu with an ancient IBM PII laptop going directly to the serial port.
The USB adapter otherwise works perfectly and I can monitor and datalog to my hearts content with it.
Does the USB adapter throw off the timing of the Calumsult dump routine???
