Nissan Primera (P10E) SR20Di .adr file - SR20 Forum
Old 06-08-2006, 12:44 PM   #1 (permalink)
src
Hello, guys!
Did you have SR20Di (P10E) correct .adr file?
My friend have that motor (single point injection) on his european Primera P10, as he wants to change his cams, he's need some portion of ECU tuning. I'll do it for him, just need an address map.
Thanks
src is offline   Reply With Quote
Old 06-08-2006, 12:50 PM   #2 (permalink)
ClamSlut
Calum's Avatar
Feedback Score: 26 reviews
Post the rom from it and I'll take a look.
Old 06-10-2006, 10:41 AM   #3 (permalink)
src
Okey, thanks Calum. You are the best!
I'll make a dump from his car and post here.
Old 06-25-2006, 01:18 PM   #4 (permalink)
src
Attached Primera Euro SR20Di rom...
Interesting things: it has Lucas ECU, it has a second board attached inside, but has no 40-pin interface. It has (I think UV-eraseable) ROM inside on main board. So it may be changed to flash-type memory and must be directly reprogrammable?
More interesting things: I've plugged SR20DE (from Infinity G20) ECU to SR20Di motor... And it was able to start and running!!! No errors codes was detected in ECU. Just one thing I have seen as abnormal: tachometer won't show any readings.
So, these ECUs are interchangeable? Maybe I need to try run Di ECU at my DE motor?
Old 06-26-2006, 09:53 AM   #5 (permalink)
ClamSlut
Calum's Avatar
Can you take some pictures of the inside of that ecu and post them?
Old 06-26-2006, 03:41 PM   #6 (permalink)
src
Yep I have them!
Nissan Primera (P10E) SR20Di .adr file-dscf0441w-lucas-ecu-insid-jpg
Nissan Primera (P10E) SR20Di .adr file-dscf0446w-lucas-ecu-cap-jpg
Old 06-26-2006, 03:50 PM   #7 (permalink)
ClamSlut
Calum's Avatar
Wow thats an oddball. It looks like an older Hitachi based ecu, wierd. What are the p/n of the three big chips?
Old 06-26-2006, 03:58 PM   #8 (permalink)
src
Yes, it is like Hitachi ECU for SR20Di.
The three big chips are:
HD63B03YCP (top chip)
HD83140CP (middle chip)
MB672451 (bottom chip)
It is ECU from a '93 Nissan Primera P10E SR20Di
Old 06-26-2006, 04:30 PM   #9 (permalink)
ClamSlut
Calum's Avatar
Intresting. Yea, thats the older 8-bit style ecu, ala KA24E, Z32, etc.
Old 06-26-2006, 04:44 PM   #10 (permalink)
src
So did you know how to program that ECU?
I will insert a 256-bit flash rom instead of a UV-erased rom and program it with the rom file I have posted before? What's about an address map for that file?
Old 06-29-2006, 02:57 AM   #11 (permalink)
src
Any ideas?
Old 06-30-2006, 06:04 AM   #12 (permalink)
SE-R GREEK
Feedback Score: 8 reviews
Easier than ours:
Search for CA18DEt ECU tuni9ng. They werer like those,
Old 07-01-2006, 07:06 AM   #13 (permalink)
src
It's great!
Old 07-01-2006, 02:51 PM   #14 (permalink)
src
Calum, did you look for maps addresses in attached file?
Please help me to find them...
Old 07-09-2006, 10:33 AM   #15 (permalink)
src
Calum, any ideas?
Old 05-02-2007, 04:02 AM   #16 (permalink)
src
Found some maps in this ECU. Can post if anyone interested. Still can't find rev limiter address. Who can help me?
Old 05-02-2007, 05:33 AM   #17 (permalink)
vzr-n1's rule
bazza1600's Avatar
rev limiter &h7788
bazza1600 is offline   Reply With Quote
Old 05-02-2007, 10:46 AM   #18 (permalink)
src
It is not at 7788.
The rev limiter something about 6500 rpm, not 7500.
The runs graph and data attached.
Nissan Primera (P10E) SR20Di .adr file-run-data-gif
Old 05-02-2007, 10:49 AM   #19 (permalink)
src
There is no 6500 16-byte limiter found, it must be HEX 0208 value.
I've tried to test some 8-bit 6500 rev limiter values, it must be HEX 82 value.
As the maps seems to be all in &7000+ area, I've tried
71F9 - no result
7AB3 - no result
7CE3 - no result
7FF9 - no result, engine does not starting at all...
Old 05-02-2007, 10:51 AM   #20 (permalink)
src
So many '82' hex in rom file, to many time needed to test all locations. anybody knows how to find actual rev limiter?
