MAF bored. Which changes need to be done? - SR20 Forum
Old 06-09-2006, 03:55 AM   #1 (permalink)
src
Hello!
I have a bored to 54mm MAF for my 100NX GTi.
What changes I need in my ECU program?
Just change "K" constant, or I need to modify VQ map?
Thanks!
src is offline   Reply With Quote
Old 06-09-2006, 07:03 AM   #2 (permalink)
NX2000 Racer
Greg Amy's Avatar
Feedback Score: 9 reviews
Well, if you're MAF is bored, just give it something to occupy its mind for a while. TV or Internet access usually works...
Kakashi Racing
2006 ARRC/NARRC/NERCC, 2008 NARRC/NERCC ITA Champions!
1993 VE-Powered Electric Blue NX2000 (street rod)
Greg Amy is offline   Reply With Quote
Old 06-09-2006, 08:30 AM   #3 (permalink)
Garbage in Garbage out
Just the K value.
If you have access to a wideband then you might want to make sure you AF's are still correct at lower rpms.
Jason
1992 240SX
2006 WRX (wingless non TR)
Old 06-10-2006, 10:48 AM   #4 (permalink)
src
Grega, ha-ha.
I like to hear how you will speak Russian.
Old 06-10-2006, 11:10 AM   #5 (permalink)
src
Calum, I want to hear your opinion!
54/50=1.08
So I must multiply the "K" value by 1.08, right?
Old 06-11-2006, 01:15 AM   #6 (permalink)
ClamSlut
Calum's Avatar
Feedback Score: 26 reviews
I like Greg's suggestion. :p
I don't remember off the top of my head. Search in this forum for a post by Jrios, he documents in a thread the right k-number to use. Its a really old post.
Old 06-12-2006, 04:45 AM   #7 (permalink)
src
Hm.. How he found 1.05 multipler?
Old 06-12-2006, 12:18 PM   #8 (permalink)
retired
Shouldn't it be 1.16?
NOT SR20 POWERED
needs.
Old 06-12-2006, 12:33 PM   #9 (permalink)
JRios's Avatar
Feedback Score: 7 reviews
This is the thread Calum is talking about,
http://www.sr20forum.com/rom-ecu-tuning-file-exchange/98100-k-value-bored-maf-370cc-injectors.html
Now, keep in mind that the size of the maf that I was trying to do is 53.5 mm. I still have not tested this theory due to extreme lack of time. So keep in mind, like I said in my post, it has to be tested.
Jorge
1996 SE-R
Old 06-12-2006, 12:54 PM   #10 (permalink)
retired
Bored MAF:
Area of a circle: pi * r^2
Area of 54mm maf: 2290.22mm
Area of 50mm maf: 1963.49mm
2290.22 / 1963.49 = 1.1664
The 54mm maf is 16.6% larger then the 50mm maf.
Old 06-13-2006, 04:54 PM   #11 (permalink)
src
Yep, I think the same manner.
And as we can found here:
http://www.sr20forum.com/technical-information-library/149465-maf-size-part-s-whp-output.html
SR20DE MAF 91-94 Sentra SER, part # 53J00
50mm 250 WHP-----------Bored 54mm 290 WHP
290 / 250 = 1.16
