J,
Good news and bad news. Good news: I finally got your ecu (the PO only delivers packages once a week to my home addy, and the first time they just leave a signature slip, hence the looooong delay). Also, I've always wanted to see what a '98 ecu looks like. Bad news: I can't do jack for this ecu, its a '98.
The give away sign btw, if you pop the top on a B14 ecu and check the crystals, the early ecus have to mcus both running at 8mHz, and one is marked m37780. On the later ecus, there are still two mcus but they run at 14 and 16mhz. The chips are only labeled with in-house numbers too, nothing to give away what they really are.
Do you want me to hold this ecu until I get your second one, or just ship it straight back?
-Calum
