B13/S13 known map addresses - SR20 Forum
Old 07-13-2006, 05:37 PM   #1 (permalink)
ClamSlut
Calum's Avatar
Feedback Score: 26 reviews
Please do not post this on other forums.
By request, here's the big chunk of my list. Lots of this is only written down in my notes, I'll sort through all those eventually.
It needs the units and x-axes added, if someone wants to work those out I'll update the list. Or someone could put it in a better format. Excel maybe?
This is probably missing some of the newer stuff thats been documented, and may have some errors in it. Post it in this thread and I'll correct it.
Anybody want to sticky this?
$000A-000B - K-value
$001B - Injector null time
$001A - Injector voltage adjuster
$0038 - Fedback switches (binary flags, not a numerical value)
$005C-005D - sometimes rev limit
$05C0-05C1 - sometimes rev limit
$0056-0057 - KA24DE 5th gear rev limit
$0031 - sometimes speed limit
$05C9 - sometimes speed limit
$05C0 - sometimes speed limit
$0700-077F - VQ map
$062F-0610 - Water temp sensor calibration map (it is backwards)
$0100-01FF - Primary fuel map
$0E00-0EFF - Secondary fuel map
$00F0-00FF - Fuel TP axis
$00E0-00EF - Fuel RPM axis
$0D00-0DFF - Primary ignition map
$0800-08FF - Secondary ignition map
$0490-049F - Ignition TP axis
$0480-048F - Ignition RPM axis
$03A0-03AF - TTP Max
$0A00-0A0F - TTP Min
$02F0-02FF - TP Limit (high boost fuel cut)
$0200-020F - Acceleration increase volume ???
$0A00-0A1F - First water temp revision ??? this is wrong?
$0220-022F - Spray water temp offset
$0230-023F - Int spray TP offset
$0610-061F - Water temp map 3 ???
$0620-062F - Water temp map 4 ???
$0C40-0C4F - Dwell duty cycle, SR20DET with coil packs
$0320-032F - Starting injector pulsewidth
$0660-066F - Idle map
$0310-031F - EgStart gain offset
$0330-033F - EgStart pulse Offset
$00A0-00AF - Throttle Open Offset
$00D0-00DF - Water temp RPM gain
$00B0-00BF - Low water temp fuel offset
$0390-039F - Q offset RPM table
$03B0-03BF - Sequential spray end
$06A0-06AF - Dashpot duty
$0690-069F - EgStart Duty Table
$0680-068F - Open loop ISC min
$0450-045F - Starting ignition timing
$0460-046F - Idle ignition in neutral
$0470-047F - Idle ignition in gear
$0510-051F - Electrical angle offset
$04A0-04AF - Cold start timing advance
$04B0-04AF - Deceleration (Cold?) ignition timing advance
$04C8-04CF - Idle stabilization timing retard
$0AC0-0ACF - No translation
$0AD0-0ADF - No translation
$0AE0-0AEF - No translation
Pictures for the no translation stuff:
If anyone can get those translated I'd appreciate it.
Edit: I want to figure out what $0090 and $0F90 are. They're both 16 byte long 2-D tables, no clue what the axis would be.
Old 07-13-2006, 06:16 PM   #2 (permalink)
src
Wow! Thanks!
A bit more, I've discovered them today.
$4A0-$4AF - Cold start timing advance
$4B0-$4AF - Desceleration (Cold?) ignition timing advance
$4C8-$4CF - Idle stabilization timing retard
You know, your idle timing is jumping if you have huge cams: try to set this map to lower values - you find your timing pretty stable!
My current setup for JWT C3 Cams is:
$4C8: 00 00 00 00 00 00 02 04
Do not set it all to 00 values - it's my suggestion! ;-)
Calum, please test $4F0-$4FF and $500-$50F if you can. There are 2 ignition maps, I think. I have no time to test them - I'm going to competitions at weekend.
src is offline   Reply With Quote
Old 07-14-2006, 11:35 AM   #3 (permalink)
ClamSlut
Calum's Avatar
Added. I won't have a chance to do anything until monday. We need to document how to build an engine simulator to make this stuff easier. I wrote some code to do the distributor signals, I need to post it.
Good find on the idle stabilization!
What are the first four bytes at 04C0-04C4? Any idea?
Old 09-10-2006, 12:10 PM   #4 (permalink)
JRios's Avatar
Feedback Score: 7 reviews
EDIT, nevermind. Off topic.
Jorge
1996 SE-R
Old 12-25-2006, 10:59 AM   #5 (permalink)
Luke Pighetti
Taiden's Avatar
Feedback Score: 3 reviews
Engine simulator??? I'm intruiged..
Old 01-23-2007, 11:42 AM   #6 (permalink)
allmotorKA24DE
thinnertenor's Avatar
question, when you refer to these codes applying to the S13, is that only the SR20 S13, or would this stuff be compatible on the KA?
B.J. Walker
1993 Aztec Red NX2000
1993 White 240sx Hatchback
thinnertenor is offline   Reply With Quote
Old 01-30-2007, 04:42 PM   #7 (permalink)
src
Calum, any update on Rom addressess from you?
What about an emulator building progress?
Old 01-30-2007, 04:55 PM   #8 (permalink)
ClamSlut
Calum's Avatar
Yea, I need to post an update for this.
Emulator is just about done. V0 has been running great for a while, V1 should be in testing later this week.
Old 03-08-2007, 05:23 AM   #9 (permalink)
src
Calum, please post an update! Can't wait anymore!
PS: pls check your email. I've asked for dautherboard OrCard
schematic and layout files. Thanks!
Old 03-25-2007, 03:27 AM   #10 (permalink)
VIVA MEXICO CABRONES!
Feedback Score: 20 reviews
[IMG
http://www.calumsult.com/calumsu/no%20translation.JPG[/IMG]
Translation:
28:
基本減速減量率: Base deceleration loss ratio
補正率: Correction ratio
(小) Small スロットル開度 Throttle Aperture (大) Large
29:
減速減量回転補正:Deceleration loss rpm correction
低回転 Low RPM エンジン回転数 Motor RPM 高回転 High RPM
30:
減速減量水温補正 Deceleration loss Water Temp Correction
低温 Low Temp エンジン水温 Motor Water Temp 高温 High Temp
hope this helps.
Sato
1 bar loop mod.. 15PSI power!
WE ARE A COMMUNITY!!!
SOMOS UNA GRAN COMUNIDAD!!!
GSRMx is offline   Reply With Quote
Old 03-25-2007, 08:51 AM   #11 (permalink)
ClamSlut
Calum's Avatar
Ah, thats interesting. 0AD0 is a percentage multiplier applied to 0AC0. I'll have to see if I can simulate this.
Old 03-30-2008, 05:02 AM   #12 (permalink)
I was looking through the S13 xdf and I noticed these 2 items-
00D0 - Cold Start - Moving - Secondary
and
0FC0 - Throttle Enrichement - Fast Movement
are using the same address "00D0"
Perhaps xdf needs updating?
ghostchild316 is offline   Reply With Quote
