B14 fuel maps - SR20 Forum
Old 09-03-2006, 11:50 PM   #1 (permalink)
Boost Addict Anon Member
Feedback Score: 12 reviews
B14 fuel maps
Anybody with a working b14 calum ecu started adjusting these?
I have been looking at these and I think I have it figured out, but from what I figured out the scale between the two (b13 and b14) is very different (128 is closed loop, 128 offset fuel value for all others). (b13 with its ~192 offset)
However what I don't get is the b13's looked to allow variations in closed loop fuel.
If others haven't figured it out by the time I get my ecu I know I can figure it out, but I'd prefer to be able to hit a more accurate tune the first time out of the gate for the turbo.
2k1 Sentra SE "Stock"
wnwright is offline   Reply With Quote
Old 09-05-2006, 06:05 PM   #2 (permalink)
ClamSlut
Calum's Avatar
Feedback Score: 26 reviews
B14s work a little different. In a B13 ecu the fuel map is a multiplier of the calculated TP (where TP is the theoretical pulsewidth needed for 14.7:1 AFR). The 8th bit (hence 'big' numbers) indicated closedloop operation. For B14s the fuel map is directly in target AFR, where 128 is 14.7:1. You can translate the fuel map by (#/128) * 14.7 = target AFR. Where the ecu switches from closed to open loop is no longer set in the fuel map. I suspect careful reading of the FSM might offer some information on that point (its amazing what Nissan puts in the FSM, you just have to read carefully, there are descriptions of the stock fuel and timing maps in the FSM).
Whats neat is you've got some maps you can start comparing to see how everything works. Dig up the '94 rom I've posted somewhere, and compare that to a '93 rom. That gives an almost direct comparison on what a fuel map looks like in a B14-style ecu vs the oldB13/S13. Then find a S14/S15DET rom and check that out, it should give you an excellent turbo fuel map to start with. All you have to do is set your k-number and injector latency correctly. Btw, latency I think is the exact same, but obviously the k-numbers are way different, that you just have to tune to find.
Old 09-05-2006, 06:19 PM   #3 (permalink)
Cool thanks.
FSM... last place I would think to look for ecu information. LOL
Old 09-05-2006, 08:58 PM   #4 (permalink)
Calum do you mean (128/#) * 14.7 ????
Since all the numbers are larger than 128 dividing by 128 would result in all target numbers larger than 14.7
Also where would I get s14/s15 roms? I started searching but I'm finding bunch of random sites.
Old 09-06-2006, 09:25 AM   #5 (permalink)
ClamSlut
Calum's Avatar
Yea, sorry.
Let me see if I can dig up some S14/S15 roms.
Old 09-06-2006, 09:55 AM   #6 (permalink)
Cool. Thanks a bunch
