I have run into an issue with entering hex numbers for the b14 K value and have a work around to share. I have experienced this problem with romeditor 1.98.48e and LiveEdit Final. I have not tested any other editors.
First if your hex number is only 3 digits long it will convert it to 4 by adding a 0 at end (very bad). Also if your 4 digit number ends in H it will convert it to a 0 (also very bad). This is the issue that I have run into.
The solution that I figured out to is to add a 0 to the front of the hex number and it doesn't change it and gives you the correct K value.
Example:
400 dec is 190 or 190h hex which gets changed to 1900 hex (6400 dec) when saved, but if you enter the hex value as 0190 it does not change it.
This problem caused me great headache when I kept burning leaner and leaner roms and it still was dumping fuel. Then I figured this out and everything ran 'smooth'.
2k1 Sentra SE "Stock"
