obd1 b14 w/ calum ecu... - SR20 Forum
Old 12-20-2006, 10:26 PM   #1 (permalink)
4th sr20 and counting..
zipstrips's Avatar
Feedback Score: 21 reviews
calum, i am probably the only one here with this (if im not please let me know!) but i have coalations obd2 - obd1 conversion harness and i am using your ECU. (everything inside the ecu) i cannot connect for some reason. would u happen to know why would you? i did have it working in the b13 prior too so i know its not the cable. i have no ill effects with the harness/ecu in the car. everything is working correctly.
once i do figure out how to connect, how can i check codes sense the turn screw isnt there anymore?
SHIFT_multiplication!
01. Audi TT 225
98. the zips machine
95. t28 setup
95. Celica, 3SGTE
90. Miata BP swap
Old 12-20-2006, 10:30 PM   #2 (permalink)
Calum Supporter
Feedback Score: 23 reviews
once its connected on conzult there is the option for trouble codes click that. make sure the plug didnt come disconnected inside the ecu also make sure to select com6 i think its the same for everyone
NewEnglandSR20's / Noise-O Fabrication
Originally Posted by Jackson Diamond View Post
You have no idea what you are spouting here. The welds in the picture are amazing. It aluminum, its not gonna weld like stainless.
fu*k it, I am waisting my time replying to you. You are a idiot and thats that.
G-Unit91 is offline   Reply With Quote
Old 12-21-2006, 04:32 PM   #3 (permalink)
zipstrips's Avatar
i can only choose from com 3 or 5..
i need to find conzult software now....
Old 12-21-2006, 08:02 PM   #4 (permalink)
Calum Supporter
choose the 5 then try that. you can dl conzult in one of calums threads
Old 12-21-2006, 08:02 PM   #5 (permalink)
Calum Supporter
http://www.sr20forum.com/calumsult-archived-informational-purposes/156312-what-consult-faq.html
Old 12-24-2006, 08:05 PM   #6 (permalink)
zipstrips's Avatar
i have a 98.......
"In 1998 they switch to the consult-II, and I do not work with that."
when i do my turbo setup, i guess ill be good to use my b13 jwt ecu thou? i could than check codes with the turn screw.....
