Improved Touring A SR20DE Bin - SR20 Forum
Old 03-22-2007, 04:52 PM   #1 (permalink)
NX2000 Racer
Greg Amy's Avatar
Feedback Score: 9 reviews
Attached is the BIN file we developed during the March 3rd CT dyno day (see below links), using CalumSult's new Real Time ECU on a DynaPack loaded hub dyno. Also attached is an Excel spreadsheet with the torque, horsepower, and AFR numbers.
This engine is a stock-based build, done to SCCA's Improved Touring category, with the following mods:
- 1mm overbore, stock compression pistons
- 1/2 point compression via head and block milling
- Balanced and blueprinted
- Port-matched but *not* ported
- New cams, valves, rockers
- UOR crank pulley
- Hotshot Gen 6 header to 3" open exhaust
- JWT POP
- Stock injectors, FPR, ignition
- Stock flywheel, JWT PP and B14 disc
http://www.sr20forum.com/calumsult-archived-informational-purposes/188165-i-will-ct-march-3rd.html
http://www.sr20forum.com/all-motor/190058-calum-tunning-ct.html
Kakashi Racing
2006 ARRC/NARRC/NERCC, 2008 NARRC/NERCC ITA Champions!
1993 VE-Powered Electric Blue NX2000 (street rod)
Greg Amy is offline   Reply With Quote
Old 03-22-2007, 04:57 PM   #2 (permalink)
Calum Supporter
Feedback Score: 23 reviews
this is going to be a excellent section
NewEnglandSR20's / Noise-O Fabrication
Originally Posted by Jackson Diamond View Post
You have no idea what you are spouting here. The welds in the picture are amazing. It aluminum, its not gonna weld like stainless.
fu*k it, I am waisting my time replying to you. You are a idiot and thats that.
G-Unit91 is offline   Reply With Quote
Old 04-10-2007, 03:48 PM   #3 (permalink)
NX2000 Racer
Greg Amy's Avatar
Update on this BIN.
During our dyno day, we were using a handheld infrared pyrometer to measure EGTs at the primary header tubes. We noticed one cylinder (#2) was running 75-100 hotter than the rest. After we got it home I removed the injectors and sent them off to Marren Injection for inspection, cleaning, and overhaul. The data sheet on return showed a resultant ~4% increase in flow rate and a reduction in variability from 4% to 1%.
I ran this program last weekend at VIR, and the car was running pig rich. Whereas we were showing AFRs of mid-to-high 13s on the dyno prior to injection work, during this last race we were getting AFRs of mid-to-high 11s according to the NGK wideband (logged to DL-1). The spark plugs were BLACK. I dind't have time (or motivation) to mess with it that weekend, but at least we still won the race...
Soooo....I've got a test day and race weekend coming up next week. I'll diddle with the K-factor a bit to lean it out and try to get the AFR to at least the low-13s, and then after that I'll schedule a dyno day to tweak it to get better numbers... - GA
P.S., on edit: we're not using an O2 sensor. We're relying entirely on programming to handle this mixture.
Old 05-03-2007, 02:49 PM   #4 (permalink)
NX2000 Racer
Greg Amy's Avatar
Update: last race we changed the injector k-factor in this program to 30000 (thirty thousand) and the general A/FRs were much improved: low-13s a low RPM to low-12s at high RPM. However, they're not consistently "good" across the range so look for some dyno tuning soon on this.
Old 06-20-2008, 09:01 PM   #5 (permalink)
Feedback Score: 3 reviews
Is there a way I can use this on B14?
98' SE-R sold!
95' G20t VE N1's (DD)
seguroski is offline   Reply With Quote
Old 08-22-2009, 01:11 AM   #6 (permalink)
but young at heart
Did you come up with a good final bin? I'd like to load something to my B13 NX with 10:1 UK motor.
"I am the gatekeeper of my own destiny and I will have my glory day in the hot sun." - who said that?
oldman is offline   Reply With Quote
Old 08-23-2009, 03:32 PM   #7 (permalink)
NX2000 Racer
Greg Amy's Avatar
Attached was the last one we did, in November 2007. I no longer have the race car so this is gonna be about it...
BEWARE: we did ZERO tuning on anything but WOT through the racing range. Otherwise, this is a stock US-spec SR20DE map...
Old 08-23-2009, 06:05 PM   #8 (permalink)
Funny to see this brought back up, I used your old bin/bins for a long time.
93 NX2000-7.75@92mph 5SPD SWAP, 2120lbs. JDM Motor, Calumsult Realtime ECU, BC3 cams/gears, CP XTP 9.2:1 pistons, NX DP-100 shot, 333's, N60, Prothane Mounts, ACT Xtreme/sprung 6 puck, Fidanza, PR WAI with JWT POP, 2.5" SSAC, Dynomax 3" muffler, Outlaw Intake Spacers, OEM wires, ngk plugs, UR Pulleys, Walbro 190, ST springs with KYB's, Kinetik KR912, Axis maglites
Old 08-23-2009, 11:23 PM   #9 (permalink)
but young at heart
The bin you mention was for a high-comp motor? How did it run on the street?
