Anyone know what maps are read in limp mode? - SR20 Forum
Old 04-01-2007, 09:47 AM   #1 (permalink)
Whut?That Ain't No Hondah
Feedback Score: 5 reviews
I've got a bin that runs super lean during normal operation while idling, but when I unhook the maf, the afr drops to 10:1 at idle.
Does anyone know where these limp mode maps are read from? Does they read the programed K values? Or the stock K value from some other location?
I'm trying to determine if theres an issue with my injectors not being the size they were advertised as, or if theres an issue with the program on my ecu.
Thanks for any help.
1990 2+2 TwinTurbo 300zx
1.6 to DET Swap
Engine Removal Writeup
Crim is offline   Reply With Quote
Old 04-01-2007, 07:33 PM   #2 (permalink)
looks like it reads whatever the stock values of the ecu were from some place not stored in the eeprom/program.
Fixed the problem I was having
Old 04-03-2007, 12:32 AM   #3 (permalink)
Feedback Score: 3 reviews
what was it?
needsomeparts is offline   Reply With Quote
Old 04-03-2007, 12:40 AM   #4 (permalink)
car wouldn't idle w/ my 800cc injectors because the injector latency was set wrong. If I unplugged my maf, the ecu would read values for the stock 370cc injectors and she'd idle just perfect (but drive like ass obviously)
When the injector latency was bumped up it all worked out
Old 04-03-2007, 11:38 PM   #5 (permalink)
Im idling way too lean on idle like 20afm but the second i drive or stab it its rich more like from 10.8 to 11.5. How can i change the latency? Whats the address to use
Old 04-03-2007, 11:40 PM   #6 (permalink)
what injectors do you have? What program are you using to edit your roms? I use romedit, its on the global tab under the K Value.
Old 04-04-2007, 01:50 AM   #7 (permalink)
i have sard 550cc inj, calum ecu the one you burn the chips with and i have the calumsult and nissandatascan but have not gotten a chance to use it yet.
Old 04-04-2007, 07:24 AM   #8 (permalink)
you will probably need to adjust the injector latency then to get it to run right. I have SARD 800cc injectors and it would idle at 21:1afr off the chart lean because the injector latency was set too low.
Old 04-07-2007, 11:02 AM   #9 (permalink)
a lil off topic but does a car go into limp mode if the knocksensor is messed up or unpluged
sbhoes is offline   Reply With Quote
Old 04-07-2007, 02:20 PM   #10 (permalink)
no, it'll just pull timing,
