Q45 vq map - SR20 Forum
Old 04-24-2007, 01:00 PM   #1 (permalink)
src
Q45 vq map
Hi,
anyone have a Q45 vq map?
thanks
src is offline   Reply With Quote
Old 04-24-2007, 03:22 PM   #2 (permalink)
ClamSlut
Calum's Avatar
Feedback Score: 26 reviews
...attached.
File Type: bin q45.bin (128 Bytes, 64 views)
Old 04-24-2007, 04:03 PM   #3 (permalink)
src
Thanks Calum!
How much WHP it rated?
Old 04-25-2007, 01:07 PM   #4 (permalink)
ClamSlut
Calum's Avatar
Not a clue.
Old 04-25-2007, 02:31 PM   #5 (permalink)
src
Not understood. I want to calculate the changed K value and recalculate TP scales, so I need its WHP output for base calculations.
For example,
SR20DE MAF 91-94 Sentra SER, part # 53J00
50mm 250 WHP-----------Bored 54mm 290 WHP
Q45 MAF - XXX WHP
I've missed something? You can advise me on the new re-calculation method?
Thanks!
Old 04-25-2007, 04:21 PM   #6 (permalink)
ClamSlut
Calum's Avatar
No, I haven't worked with the Q45 maf. I don't know what it is rated for.
What I would do is get a stable program with one injector/maf combo, then swap in the Q45 maf (and VQ table). Then just adjust the k value until it is stable again (no need to touch the TP scale). Doing this with a Realtime ECU is pretty easy, you can adjust the k-value while the car is running.
Old 04-27-2007, 10:15 AM   #7 (permalink)
src
Ok Calum, thanks!
