9.5:1 CR, T25, Z32, 370@4BAR Bin please
Hello guys, I damaged both of my eprom sets because I put them backwards on the ECU, anyway, I already knock myself for that, now I have a new set of chips to burn but I have no programs, can anybody give a hand here?
I'm going to need a bin with the following setup
The setup is:
9.5:1 jdm sr20de engine
t25 turbo @12psi normal drive, 17psi for the track
370's @ 4 bar
z32 MAF
consult port
I have a SAFC so if anyone have a BIN with the setup I metioned with a DE maf or something, I can make it work changing the setting of my SAFC.
as alwasy, thanks guys
Email: nnoriega@hotmail.com
1993 Sentra SE-R
Garret/Turbonetics T3/T4 turbo Trim 60 A/R .63 turbine @15psi, 2.5 inch DP, 550's@4bar, 15 degree timming, EVO VIII FMIC, SAFC II, Z32 MAF, Calum Basic ECU, AEM wideband, Blitz DD BOV, Walbro 255 lph, Nismo FPR, Prothanes motor mounts, Prothane suspension kit, Eibach sport springs with KYB II struts, ACT Extreme clutch kit, Profec A EBC, welded case.
Got Boost?
