removing egr temp sensor - SR20 Forum
Old 07-28-2007, 05:11 AM   #1 (permalink)
i have a 91 g20 mt non califonia car and would like to use another ecu(from california) modded to accept different maps.how do i bypass the egr temp sensor since my car is non-california. dowloaded the original bin file from my car to be use as base map to the modded ecu before tweaking and keeping the original ecu in original setup..help!!!
92p10 is offline   Reply With Quote
Old 07-28-2007, 09:14 AM   #2 (permalink)
eric96ser's Avatar
Feedback Score: 29 reviews
You need to either solder a resistor inside the ECU, or put it in the harness for the EGR temp sensor.
The community is here.
Old 07-28-2007, 11:30 AM   #3 (permalink)
thanks for the quick response...do you happen to know what resistor it is and what value since i'm tinkering with another ecu right now..
Old 07-29-2007, 06:35 PM   #4 (permalink)
eric96ser's Avatar
http://www.sr20forum.com/search.php?searchid=2623780
Old 07-29-2007, 08:48 PM   #5 (permalink)
SR powered
Feedback Score: 5 reviews
68K resistor from RadioShack. I just put the resistor in the connector and used eletrical tape to make sure it stays in place.
DreSEL is offline   Reply With Quote
Old 07-30-2007, 04:31 AM   #6 (permalink)
thanks guys
