Wanted B14 DET bin. . . - SR20 Forum
Old 08-25-2007, 01:11 AM   #1 (permalink)
B14 Driver
Feedback Score: 5 reviews
In need of a B14 Bin: N60 Maf, 370cc, DET 8.5:1 CR, T25 turbo.
Thanks
thewhiteone is offline   Reply With Quote
Old 08-25-2007, 01:35 AM   #2 (permalink)
ClamSlut
Calum's Avatar
Feedback Score: 26 reviews
Everything but the k-value should work just fine. Thats where I think the k-value should be. With the car fully warmed up, adjust the k-value (start with increments of 5, unless its way out to lunch to start) until at idle and part throttle cruise its around 14.7:1, and WOT its in the 11s. If its there right out of the box my guesstimate was on the money. Use TPRT to do the k-value adjustments while the car is running.
Old 08-25-2007, 03:02 AM   #3 (permalink)
B14 Driver
Thanks so much Calum! Ill try to test it tomorrow.
Old 09-05-2007, 12:55 PM   #4 (permalink)
B14 Driver
Hey Calum do you have this exact program for 4Bar instead of 3Bar? Planning on going with 4Bar. Also the Maf works fine . Let me know.
Thanks
Old 09-05-2007, 02:16 PM   #5 (permalink)
ClamSlut
Calum's Avatar
No, but I can. Give me a bit.
Old 09-07-2007, 12:59 PM   #6 (permalink)
B14 Driver
Figured it out yet Calum?
Old 09-23-2007, 03:50 PM   #7 (permalink)
4th sr20 and counting..
zipstrips's Avatar
Feedback Score: 21 reviews
hows this working out!?
SHIFT_multiplication!
01. Audi TT 225
98. the zips machine
95. t28 setup
95. Celica, 3SGTE
90. Miata BP swap
Old 12-28-2007, 11:34 AM   #8 (permalink)
officially a boost addict
Feedback Score: 10 reviews
ever get the .bin for 4 bar??
http://www.sr20-forum.com/members-ri...ebs-build.html
U13 SR20DET, Turbonetics 60-1 hi fi .63 ar, Brian Crower Stage 2's, 520cc injectors, .3 bar fuel pressure, n62 maf, log manifold, Tial 38mm wastegate (9lb spring), 3" downpipe-3" VRS Exhaust, PLX Wideband, Calum basic ecu.
Balls to the wall until you see God, wait three seconds then hit the brakes...
nsusammyeb is offline   Reply With Quote
Old 01-13-2008, 01:35 AM   #9 (permalink)
B14 Driver
BUMP
Old 01-31-2008, 08:53 PM   #10 (permalink)
bump
Old 02-06-2008, 07:24 PM   #11 (permalink)
B14 Driver
Heres the 4BAR
File Type: bin CJJ B14-SR20DET-DET INJ-N60 MAF 4BAR.bin (64.0 KB, 24 views)
