sr20ve bin - SR20 Forum
Old 09-29-2007, 03:20 AM   #1 (permalink)
VE power!
Feedback Score: 5 reviews
sr20ve bin
I'm looking for something better than what I have now.
My setup: sr20ve, Calum ECU ve basic DB, stock sr20ve cams, de maf, ve 333cc injectors, Apexi wai, 2.5" ssac header with cat and 2.5" cat-back.
I went on the dyno and had to lower my fuel pressure 4psi it was running so rich.
I'll be getting a Moates burn1 soon and I wanted to see if some one could get me closer to a better tune before I go back to the dyno. Thanks!
E's 92' sr20 is offline   Reply With Quote
Old 10-02-2007, 09:53 PM   #2 (permalink)
VE power!
Mostly I need a better afr. Mine is all wacked out. It changes from 12.5-13.32 after leaning it out with the fpr.
Old 10-11-2007, 02:06 PM   #3 (permalink)
Feedback Score: 13 reviews
Did you make more power with the fpr lower? Sorry to jack, but im running a similar setup and just want to know if this could be happening with my setup too.
Thanks
Dudeman
Old 10-18-2007, 03:44 AM   #4 (permalink)
VE power!
Yeah 8hp and 6tq at 40.5 psi hose off. But I suggest you use a wide band or get on the dyno so you can see the afr so you do'nt run lean. I've heard the apexi air filter can make my car run rich and that's how my car happened to be running.
Old 11-30-2007, 12:21 AM   #5 (permalink)
Enemy of the stupid
Feedback Score: 9 reviews
Post up a screen shot of your fuel map. I might be able to tell what #'s you need to get it down too.
91 NX2000 VE forsale
Protech-Fabrication
http://www.OSRdyno.com/
