In emanage it gives me adjustment rows based on voltage from the maf reading. If I dont know around what that is in "tp" i dont know where to make my adjustment nor do i even know what those values mean in the 16x16graph in rom editor.
For example: This is strictly timing map right now, ill worry about fuel map later.
at 4.6v on the airflow meter hot wire @ 7500 rpms what would i put in the box to compensate for:
The de base map: Only shows up to 6800 with 80 "boost" under the .26 value and the data in that square is 25.
The ve map: Shows up to 8000rpm, but ill put up the data at 6800 for comparison reasons. 6800 with 68 "boost" under the .20 value and the data in that square is 32.
What exactly does that information mean? All I get from it is that at the 6800 rpm point the ve is a higher value than the de. My questions are:
What does the different value in the "Boost" section mean? When I change injector size to 330 the numbers in the boxes above change as well as the bottom row of values. Do they simply change to compensate for the larger size of injector?
What does the 25 value in the red box mean? How does it compare to the 32 from the VE map?
Does the highest column of "boost" in rom editor equal out to the highest column of "airflow meter hot wire voltage"? If so how do i translate the data into the graph into degree of timing?
Sorry this is a lot of questions and probably a lot of babble. Ive read probably 20 pages on rom editor and ecu tuning so far in the past 2 days an none have provided me with the information im trying to get. Everyone told me to ask calum
so I appreciate your help man.
