Yes, a simple code modification placing the TP in one of the many blank consult stream offsets is required.
There is an address file which allows you to configure this TP offset (actually 2, one for fuel table(s), one for ign table(s)), so it can be placed in different locations. The ecu's which already have TP variables in the stream will be able to be configured this way as well.
This allows for up to 20 variables to be streamed at once at higher speed than the ROM/RAM dump command (that datascan uses). Even though they are not shown in the screen shot as I havent yet added it, a variety of extra sensor data will be able to be viewed/logged at same time as tracing.
Some pre-modified .bins will be included for ka24e, ka24de, sr20de along with address file (actually .spd file in this case)
Also included in the address file is configuration of all available table and rpm/TP axi , so yes it can be used with basically any nissan ecu. Even those without consult support would be able to view and edit the tables.
www.hybridka.com
1991 g20
1988 bagged hardbody
1992 civic d16 turbo
