Originally Posted by Calum
No, but the B13/S13 can go in crooked pretty easily. The trick is as you bolt them in squeeze both sides of the ecu/harness connector.
Also make sure the ecu doesn't have water damage. This isn't really something you usually see on an S13 ecu, but very common on B13 ecus. Just pop the top and bottom covers and look for obvious signs of damage.
thanks, i know what you mean about squeezing both sides of plug so it goes in even. my old one that works is water damaged and even has one connection that has corroded away but still works. Ill try the squeeze method with the newer computer., thanks again.
