sr20de tuned v4 - SR20 Forum
Old 07-27-2008, 11:45 PM   #1 (permalink)
Ctn
sr20de tuned v4
Can someone please post up the sr20de tuned v4 bin.
Cheers.
Ctn is offline   Reply With Quote
Old 08-09-2008, 06:27 AM   #2 (permalink)
Would this tune (come close) to suit my car? i have tomei poncams (260x11.2) fuji extractors with a 2.5" mandrel bent exhaust, stock afm and injectors, if so can someone please post it up.
CoZZm0 is offline   Reply With Quote
Old 08-18-2008, 03:02 AM   #3 (permalink)
Ctn
Pretty please
Old 04-29-2010, 08:25 AM   #4 (permalink)
Nissan Guru
BUMP
Someone must still have Calum's v4 tuned sr20 n/a bin hiding on thier computer!
95 200sx SE-R
PS Header,2.5" Exhaust,3" Intake w/ POP charger,BC stage 2 cams,Calum Basic,N60 MAF,Innovate LC-1,XTD Lightweight flywheel & Stage 2 clutch,PX3 thermal gskt,
96 Sentra 1.6(B13)
Obx Header,2.25" Exhaust,Pulleys,Calum Basic,SR20 Ecu\TB\Inj\Maf,3" to 2.5" Cold air intake,ACT Clutch,OEM Lightend flywheel,VTC (window switch),NOS
HaulinSentra is offline   Reply With Quote
Old 05-18-2010, 07:58 AM   #5 (permalink)
I have a bin for sr20det blacktop running up to 9.5 psi if you want.
EDIT: My own bin tested between 7 to 9.5 psi. No supporting mods needed although normal aspiration/cooling will help. Use it in my trackcar, not a daily bin.
kazekage is offline   Reply With Quote
Old 05-20-2010, 11:40 AM   #6 (permalink)
but young at heart
Feedback Score: 9 reviews
Cheers.
This is the one I have. I did not create this bin.
"I am the gatekeeper of my own destiny and I will have my glory day in the hot sun." - who said that?
oldman is offline   Reply With Quote
Old 06-04-2010, 08:33 AM   #7 (permalink)
Nissan Guru
Thanks oldman! Is this an unmolested bin?
Old 06-22-2010, 01:13 PM   #8 (permalink)
Hey Guys
Very new to the tuning world awesome site.
Just a question concerning the bin in this thread is this suitable for a stock sr20de i see the timing is set to 25 and 40?
mono is offline   Reply With Quote
Old 06-23-2010, 05:37 AM   #9 (permalink)
Feedback Score: 17 reviews
Haulin Sentra - I took a quick look at the bin and it looks like the original Calum v.4
Mono - Yes, it's suitable for a stock SR20DE. Set your base timing to 15* BTDC. I don't know what you mean by saying the timing is set to 25 and 40. Can you explain?
Billc
Old 06-28-2010, 07:56 AM   #10 (permalink)
SR20
Feedback Score: 4 reviews
Anybody worked with that bin? Any dyno results or impressions?
jagy is offline   Reply With Quote
Old 06-29-2010, 05:08 AM   #11 (permalink)
As with any off the shelf tune, you need to check the AFR using a wide band O2 meeting. Tune it in to 12.8 or so at WOT. That's where most of the power will be. VEs are notorious for having variable AFRs depending on the specific set up.
Depending on your gas octane, you might be able to bump the timing a little. I did not find much power by increasing the timing.
