High compression NA bin needed - SR20 Forum
Old 09-01-2008, 08:18 PM   #1 (permalink)
I've got my rally car almost ready to dyno tune.
Engine specs are 11:1, C2 cams, header + 3" exhaust, CAI. I have been running on the stock injectors and the stock MAF with Greg Amy's ITA bin while I break things in. I'm now adding an N60 MAF. Will I be able to run the same bin if I go to 370 injectors, or will I need to completely reprogram the ECU? I have a live edit Calum ECU, not the original. Any advice appreciated!
john is offline   Reply With Quote
