B14 370 INJ E60 MAF VE - SR20 Forum
Old 11-23-2008, 05:29 PM   #1 (permalink)
ClamSlut
Calum's Avatar
Feedback Score: 26 reviews
Attached.
Old 11-24-2008, 02:30 PM   #2 (permalink)
Thanks Calum do you have the bin/program for the n1 cams because that it what I have in my motor. Let me know what you can do for me
typeb14se-r is offline   Reply With Quote
Old 11-25-2008, 02:39 PM   #3 (permalink)
ClamSlut
Calum's Avatar
I've never worked with N1 cams. That was tuned for SR16 cams.
Old 11-26-2008, 01:40 AM   #4 (permalink)
Oh i see then can you modify an existing bin file for a vvl with n1 cams and just modify it for bigger 370cc injectors and e-60 maf or should I use the bin file with sr16ve cams and 370cc injectors? Also when can I ship my ecu to you so i can make it a b14 realtime ecu, I seen that SentraDude shipped his to you, so I was hoping I can ship mines to you too. Please let me know asap. Thanks Here's the link for the bin file with n1 cams and 333cc injectors: http://www.sr20forum.com/rom-ecu-tun...f-n1-cams.html
Old 11-29-2008, 10:33 AM   #5 (permalink)
ClamSlut
Calum's Avatar
I've never worked with the N1 cams. I would need to have a car on a dyno.
Old 11-29-2008, 09:51 PM   #6 (permalink)
Ok cool thanks Calum do you a bin file then for a b14 with sr20ve, n1 cams, 333cc injectors, and an e60 maf? Here I found a bin file with all my current mods but instead of an e60 maf the bin is programmed for a n60 maf. Is there a way to change the maf to an e60 maf or will the car run fine with this bin file even though it's programmed for a n60 maf? Here's the link to the bin file with all my mods but with the n60 maf. Thanks
Old 12-01-2008, 09:53 AM   #7 (permalink)
ClamSlut
Calum's Avatar
I've never worked with the N1 cams. I would need to have a car on a dyno. I've posted a bin for the VE injectors E60 maf somewhere on here, let me dig it up.
